Differences
en:uhsdr:uhsdrfw [05.02.2018 22:45] – df9ts_user | en:uhsdr:uhsdrfw [06.02.2018 08:51] – df9ts_user | ||
Line 1: | Line 1: | ||
{{tag> | {{tag> | ||
===== UHSDR Firmware ===== | ===== UHSDR Firmware ===== | ||
- | There are two options to load new firmware versions onto a working UHSDR boot loader: | + | There are two standard |
* DfuSe Tool | * DfuSe Tool | ||
* USB Stick | * USB Stick | ||
+ | ST-Link/V2 debug adapter can also be used to download new firmware | ||
==== DfuSe Firmware upgrade ==== | ==== DfuSe Firmware upgrade ==== | ||
Line 25: | Line 28: | ||
=== Further Reading === | === Further Reading === | ||
==== USB Stick Firmware upgrade ==== | ==== USB Stick Firmware upgrade ==== | ||
Line 46: | Line 49: | ||
[[https:// | [[https:// | ||
+ | ==== ST-Link/V2 Firmware upgrade ==== | ||
+ | === Preconditions === | ||
+ | * Download latest fw-40SDR.bin firmware from [[https:// | ||
+ | * Connect ST-Link/V2 with OVI40 UI and with PC. | ||
+ | * Start STM32 ST-Link Utility on PC | ||
+ | * Recent UHSDR boot loader installed and working | ||
+ | * OVI40 UI powered up | ||
+ | === Procedure === | ||
+ | * In ST-Link Utility: Target-> | ||
+ | * Start address 0x08010000 | ||
+ | * Enter file path of .bin file to program | ||
+ | * Select verify while programming | ||
+ | * Select "reset after programming" | ||
+ | * Hit " | ||
+ | * After successful programming the UHSDR FW should start | ||
+ | ==== Further Reading ==== | ||
