en:uhsdr:uhsdrfw
Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr:uhsdrfw [05.02.2018 22:36] df9ts_useren:uhsdr:uhsdrfw [06.02.2018 10:08] (current) df9ts_user
Line 1: Line 1:
-{{tag>stub}}+{{tag>review}}
 {{tag>english}} {{tag>english}}
 +<bootnote> Attention: Work in progress - page under construction</bootnote>
 ===== UHSDR Firmware ===== ===== UHSDR Firmware =====
-There are two options to load new firmware versions onto a working UHSDR boot loader:+There are two standard options to load new firmware versions onto a working UHSDR boot loader:
   * DfuSe Tool   * DfuSe Tool
   * USB Stick   * USB Stick
 +ST-Link/V2 debug adapter can also be used to download new firmware
 ==== DfuSe Firmware upgrade ==== ==== DfuSe Firmware upgrade ====
Line 25: Line 28:
 === Further Reading === === Further Reading ===
-{{ :uhsdr:en.cd00155676.pdf | ST-Micro DFuse Tool Beschreibung}}+{{ :uhsdr:en.cd00155676.pdf| ST-Micro DFuse Tool Beschreibung}}
 ==== USB Stick Firmware upgrade ==== ==== USB Stick Firmware upgrade ====
 === Preconditions === === Preconditions ===
 +  * Download latest fw-40SDR.bin firmware from [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|here]].
 +  * Format USB-Stick with FAT or FAT32 file partition. Make sure - just in case - that USB-stick is otherwise empty
 +  * Copy .bin file to stick. Make sure it is copied as file, not just a link / short-cut
 +  * Recent UHSDR boot loader installed and working
 === Procedure === === Procedure ===
-=== Further Reading ===+  * Supply +8V on JP1 pin 29 - to pwer USB stick
 +  * Push and - important - hold switch "BAND -"
 +  * Supply +5V on JP1 pin 28 - this starts the boot loader
 +  * Wait until "USB drive mode" is displayed on LCD screen, then release "band -" switch
 +  * insert USB stick into large USB port of OVI40 UI
 +  * Wait for FW upload to finish
 +  - Remove +5V, then apply again to reboot OVI40 UI.
 +==== Further Reading ====
 +[[https://github.com/df8oe/UHSDR/blob/81dd4afae1a52103b2f1824cba34e2ff35e805ea/mchf-eclipse/useful_manuals/bootloader_doc.md]]
 +[[https://github.com/df8oe/UHSDR/wiki/Firmware-Upgrades]]
-<bootnote>Einarbeiten: https://github.com/df8oe/UHSDR/blob/81dd4afae1a52103b2f1824cba34e2ff35e805ea/mchf-eclipse/useful_manuals/bootloader_doc.md</bootnote>+==== ST-Link/V2 Firmware upgrade ====
 +=== Preconditions ===
 +  * Connect ST-Link/V2 with OVI40 UI and with PC.
 +  * Start STM32 ST-Link Utility on PC
 +  * OVI40 UI powered up
 +=== Procedure ===
 +  * In ST-Link Utility: Target->Connect
 +  * In ST-Link Utility: Target->Program and Verify
 +    * Start address 0x08010000
 +    * Enter file path of .bin file to program
 +    * Select verify while programming
 +    * Select "reset after programming"
 +  * Hit "Start" to program device
 +  * After successful programming the UHSDR FW should start
-==== Firmware Installation ====+==== Further Reading ====
-<bootnote>ToDo https://github.com/df8oe/UHSDR/wiki/Firmware-Upgrades</bootnote>
-==== Fehlermöglichkeiten ====
-1) USB-Stick an die falsche Buchse gesteckt (die große ist die richtige)
-2) Stick nicht mit FAT oder FAT32 formatiert
-3) Windows hat an den Dateinamen noch was anderes "drangeschummelt" und zeigt das nicht an
-4) Verdrahtung von der großen USB-Buchse zum STM marode
-5) zu alter Bootloader (ich rede vom aktuellen Bootloader)
  • en/uhsdr/uhsdrfw.txt
  • Last modified: 06.02.2018 10:08
  • by df9ts_user
