Differences
Next revision | Previous revisionLast revisionBoth sides next revision | ||
en:uhsdr:uhsdrfw [05.02.2018 22:35] – created df9ts_user | en:uhsdr:uhsdrfw [06.02.2018 08:51] – df9ts_user | ||
Line 1: | Line 1: | ||
{{tag> | {{tag> | ||
===== UHSDR Firmware ===== | ===== UHSDR Firmware ===== | ||
- | There are two options to load new firmware versions onto a working UHSDR boot loader: | + | There are two standard |
* DfuSe Tool | * DfuSe Tool | ||
* USB Stick | * USB Stick | ||
+ | ST-Link/V2 debug adapter can also be used to download new firmware | ||
==== DfuSe Firmware upgrade ==== | ==== DfuSe Firmware upgrade ==== | ||
Line 19: | Line 22: | ||
* supply +5V to OVI40 UI (JP1 pin 28) | * supply +5V to OVI40 UI (JP1 pin 28) | ||
* keep pressing "band +" switch until "DFU upgrade mode" appears on LCD screen. You may release the "band + " switch then | * keep pressing "band +" switch until "DFU upgrade mode" appears on LCD screen. You may release the "band + " switch then | ||
- | * Use DfuSe Tool to load new firmware. Use the | + | * Use DfuSe Tool to load new firmware. Use the " |
* Reboot | * Reboot | ||
Line 25: | Line 28: | ||
=== Further Reading === | === Further Reading === | ||
==== USB Stick Firmware upgrade ==== | ==== USB Stick Firmware upgrade ==== | ||
=== Preconditions === | === Preconditions === | ||
+ | * Download latest fw-40SDR.bin firmware from [[https:// | ||
+ | * Format USB-Stick with FAT or FAT32 file partition. Make sure - just in case - that USB-stick is otherwise empty | ||
+ | * Copy .bin file to stick. Make sure it is copied as file, not just a link / short-cut | ||
+ | * Recent UHSDR boot loader installed and working | ||
=== Procedure === | === Procedure === | ||
- | === Further Reading === | + | * Supply +8V on JP1 pin 29 - to pwer USB stick |
+ | * Push and - important - hold switch "BAND -" | ||
+ | * Supply +5V on JP1 pin 28 - this starts the boot loader | ||
+ | * Wait until "USB drive mode" is displayed on LCD screen, then release "band -" switch | ||
+ | * insert USB stick into large USB port of OVI40 UI | ||
+ | * Wait for FW upload to finish | ||
+ | - Remove +5V, then apply again to reboot OVI40 UI. | ||
+ | ==== Further Reading ==== | ||
+ | [[https:// | ||
+ | [[https:// | ||
- | < | + | ==== ST-Link/V2 Firmware upgrade ==== |
+ | === Preconditions === | ||
+ | * Download latest fw-40SDR.bin firmware from [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|here]]. | ||
+ | * Connect ST-Link/V2 with OVI40 UI and with PC. | ||
+ | * Start STM32 ST-Link Utility on PC | ||
+ | * OVI40 UI powered up | ||
+ | === Procedure === | ||
+ | * In ST-Link Utility: Target->Connect | ||
+ | * In ST-Link Utility: Target-> | ||
+ | * Start address 0x08010000 | ||
+ | * Enter file path of .bin file to program | ||
+ | * Select verify while programming | ||
+ | * Select "reset after programming" | ||
+ | * Hit " | ||
+ | * After successful programming the UHSDR FW should start | ||
- | ==== Firmware Installation | + | ==== Further Reading |
- | ==== Fehlermöglichkeiten ==== | ||
- | 1) USB-Stick an die falsche Buchse gesteckt (die große ist die richtige) | ||
- | 2) Stick nicht mit FAT oder FAT32 formatiert | ||
- | 3) Windows hat an den Dateinamen noch was anderes " | ||
- | 4) Verdrahtung von der großen USB-Buchse zum STM marode | ||
- | 5) zu alter Bootloader (ich rede vom aktuellen Bootloader) |
