Differences
en:projekte:ovi40-sdr:bom [08.12.2017 12:25] – yd0rwo | en:projekte:ovi40-sdr:bom [11.03.2018 10:51] (current) – [UI-PCB:] yd0rwo | ||
Line 1: | Line 1: | ||
+ | ===== Bill of Material (BoM) ===== | ||
Here you can find the recent Bill of Materials for OVI40-SDR. | Here you can find the recent Bill of Materials for OVI40-SDR. | ||
- | ====== UI-PCB: | + | ==== UI-PCB: ==== |
**Please pay attention! This BOM is a preliminary and might change during betatest phase.** | **Please pay attention! This BOM is a preliminary and might change during betatest phase.** | ||
Line 17: | Line 20: | ||
|IC6|KA78RM33R|3, | |IC6|KA78RM33R|3, | ||
|IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/ | |IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/ | ||
- | |IC8|NCP5501DT50G|5, | + | |IC8|NCP5501DT50G|5, |
|Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0, | |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0, | ||
|T3|BC857|PNP Transistor|SOT23|1|179-8067|0, | |T3|BC857|PNP Transistor|SOT23|1|179-8067|0, | ||
Line 29: | Line 32: | ||
|D2|red|LED|LED_3MM|1|276-4977|0, | |D2|red|LED|LED_3MM|1|276-4977|0, | ||
|D3|blue|LED|LED_3MM|1|276-4975|0, | |D3|blue|LED|LED_3MM|1|276-4975|0, | ||
- | |BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2,98| | | | |BU2032-1-ND|0, | + | |BAT1-HOLDER| |Battery Holder CR2032| |1|131-9749|2,98| | | | |BU2032-1-ND|0, |
|BAT1|CR2032P_L|Lithium Battery 3, | |BAT1|CR2032P_L|Lithium Battery 3, | ||
|X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0, | |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0, | ||
Line 220: | Line 223: | ||
|C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | | |C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | | ||
- | |S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0, | + | |S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0, |
|S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
|S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
Line 239: | Line 242: | ||
|S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
- | |J1|1503_07|Audio Plug 3, | + | |J1|1503_07|Audio Plug 3, |
|J2|1503_07|Audio Plug 3, | |J2|1503_07|Audio Plug 3, | ||
|J3|1503_07|Audio Plug 3, | |J3|1503_07|Audio Plug 3, |
