en:projekte:ovi40-sdr:bom
Differences
Link to this comparison view
Next revision
Previous revision
en:projekte:ovi40-sdr:bom [08.12.2017 12:34] yd0rwoen:projekte:ovi40-sdr:bom [11.03.2018 10:51] (current) – [UI-PCB:] yd0rwo
Line 1: Line 1:
 +{{tag>english}}{{tag>review}}
 +===== Bill of Material (BoM) =====
 Here you can find the recent Bill of Materials for OVI40-SDR. Here you can find the recent Bill of Materials for OVI40-SDR.
-====== UI-PCB: ======+==== UI-PCB: ====
 **Please pay attention! This BOM is a preliminary and might change during betatest phase.** **Please pay attention! This BOM is a preliminary and might change during betatest phase.**
Line 17: Line 20:
 |IC6|KA78RM33R|3,3 Volt LDO|DPAK|1|245-1041|0,681|TS 2940 CP33| |821-TS2940CP33| | | | |IC6|KA78RM33R|3,3 Volt LDO|DPAK|1|245-1041|0,681|TS 2940 CP33| |821-TS2940CP33| | | |
 |IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/SN| |AT24CM02-SSHM-B-ND|1,89| |IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/SN| |AT24CM02-SSHM-B-ND|1,89|
-|IC8|NCP5501DT50G|5,0 Volt LDO|DPAK|1|170-3369|0,602|TS 2940 CP50| |821-TS2940CP50| | | |+|IC8|NCP5501DT50G|5,0 Volt LDO|DPAK|1|170-3369|0,602|TS 2940 CP50| |863-NCP5501DT50G| | | |
 |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0,6| |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0,6|
 |T3|BC857|PNP Transistor|SOT23|1|179-8067|0,02|BC 857C SMD|0,034|771-BC857CW115| | | | |T3|BC857|PNP Transistor|SOT23|1|179-8067|0,02|BC 857C SMD|0,034|771-BC857CW115| | | |
Line 29: Line 32:
 |D2|red|LED|LED_3MM|1|276-4977|0,361|LED 3MM ST RT| |710-151034RS03000| | | | |D2|red|LED|LED_3MM|1|276-4977|0,361|LED 3MM ST RT| |710-151034RS03000| | | |
 |D3|blue|LED|LED_3MM|1|276-4975|0,443|LED 3MM ST BL| |710-151034BS03000| | | | |D3|blue|LED|LED_3MM|1|276-4975|0,443|LED 3MM ST BL| |710-151034BS03000| | | |
-|BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2,98| | | | |BU2032-1-ND|0,66|+|BAT1-HOLDER| |Battery Holder CR2032| |1|131-9749|2,98| | | | |BU2032-1-ND|0,66|
 |BAT1|CR2032P_L|Lithium Battery 3,0Volt|CR_2032_H|1| | |CR 2032P-H| | | | | | |BAT1|CR2032P_L|Lithium Battery 3,0Volt|CR_2032_H|1| | |CR 2032P-H| | | | | |
 |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0,81|USB AW|0,2| | | | | |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0,81|USB AW|0,2| | | | |
Line 239: Line 242:
 |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | |
-|J1|1503_07|Audio Plug 3,5mm|1503_07|3|121-7016|2,26|LUM 1503-07|0,59| | | | |+|J1|1503_07|Audio Plug 3,5mm|1503_07|3| |2,26|LUM 1503-07|0,59| | | | |
 |J2|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | | |J2|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | |
 |J3|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | | |J3|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | |
  • en/projekte/ovi40-sdr/bom.txt
  • Last modified: 11.03.2018 10:51
  • by yd0rwo
