en:projekte:ovi40-sdr:bom
Differences
Link to this comparison view
Next revision
Previous revision
en:projekte:ovi40-sdr:bom [27.09.2017 18:14] – created df8oeen:projekte:ovi40-sdr:bom [11.03.2018 10:51] (current) – [UI-PCB:] yd0rwo
Line 1: Line 1:
 +{{tag>english}}{{tag>review}}
 +===== Bill of Material (BoM) =====
 Here you can find the recent Bill of Materials for OVI40-SDR. Here you can find the recent Bill of Materials for OVI40-SDR.
-====== UI-PCB: ======+==== UI-PCB: ====
 **Please pay attention! This BOM is a preliminary and might change during betatest phase.** **Please pay attention! This BOM is a preliminary and might change during betatest phase.**
Line 7: Line 10:
 E.g.the SD-Cardreader which is listed here will be replaced in series because it is no longer available. E.g.the SD-Cardreader which is listed here will be replaced in series because it is no longer available.
-|BOM OVI40-SDR UI V1.7||24-09-2017|DF8OE| ||Distributor / Prices||||||+|BOM OVI40-SDR UI V1.7||24-09-2017|DF8OE| ||Distributor / Prices|||||| |
 ^Part^Value^Description^Package^Amount^FARNELL^Price^Reichelt^Price^Mouser^Price^Digikey^Price| ^Part^Value^Description^Package^Amount^FARNELL^Price^Reichelt^Price^Mouser^Price^Digikey^Price|
 |IC1 /IC12|WM8731|Audio CODEC WM8731|SSOP28|2| | | | |238-WM8731SEDS/V| |WM8731SEDS/RVCT-ND|3,63| |IC1 /IC12|WM8731|Audio CODEC WM8731|SSOP28|2| | | | |238-WM8731SEDS/V| |WM8731SEDS/RVCT-ND|3,63|
Line 14: Line 17:
 |IC3|LP5907_Q1|TI low noise LDO 3,3 Volt|SOT23-5|1|249-2304|0,654| | |595-LP5907QMFX-3.3Q1| |296-38557-1-ND|0,47| |IC3|LP5907_Q1|TI low noise LDO 3,3 Volt|SOT23-5|1|249-2304|0,654| | |595-LP5907QMFX-3.3Q1| |296-38557-1-ND|0,47|
 |IC4|STM32F76X_ZIT6|MCU|LQFP144|1|253-5499|12,84| | |511-STM32F767ZIT6| |497-16521-ND|13,26| |IC4|STM32F76X_ZIT6|MCU|LQFP144|1|253-5499|12,84| | |511-STM32F767ZIT6| |497-16521-ND|13,26|
-|IC5|ASTX-H11|16 MHz TCXO  2,5ppm  3,2 x 2,5 mm|TCXO_32X25|1| | | | |815-ASTXH1116T| |535-12044-1-ND|2,84|+|IC5|ASTX-H11|16 MHz TCXO 2,5ppm 3,2 x 2,5 mm|TCXO_32X25|1| | | | |815-ASTXH1116T| |535-12044-1-ND|2,84|
 |IC6|KA78RM33R|3,3 Volt LDO|DPAK|1|245-1041|0,681|TS 2940 CP33| |821-TS2940CP33| | | | |IC6|KA78RM33R|3,3 Volt LDO|DPAK|1|245-1041|0,681|TS 2940 CP33| |821-TS2940CP33| | | |
-|IC7|AT24CM02|I2C  EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/SN| |AT24CM02-SSHM-B-ND|1,89| +|IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/SN| |AT24CM02-SSHM-B-ND|1,89|
-|IC8|NCP5501DT50G|5,0 Volt LDO|DPAK|1|170-3369|0,602|TS 2940 CP50| |821-TS2940CP50| | | |+|IC8|NCP5501DT50G|5,0 Volt LDO|DPAK|1|170-3369|0,602|TS 2940 CP50| |863-NCP5501DT50G| | | |
 |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0,6| |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0,6|
 |T3|BC857|PNP Transistor|SOT23|1|179-8067|0,02|BC 857C SMD|0,034|771-BC857CW115| | | | |T3|BC857|PNP Transistor|SOT23|1|179-8067|0,02|BC 857C SMD|0,034|771-BC857CW115| | | |
 |D5|BAV70|Double Diode|SOT23|2|267-7467|0,031|BAV 70 SMD|0,034|512-BAV70| | | | |D5|BAV70|Double Diode|SOT23|2|267-7467|0,031|BAV 70 SMD|0,034|512-BAV70| | | |
 |D6|BAV70|Double Diode|SOT23|.| | | | | | | | | |D6|BAV70|Double Diode|SOT23|.| | | | | | | | |
-|D7|BAS85|Schottky barrier diode |SOD80C|3|146-9394|0,23|BAS 85 SMD|0,034|771-BAS85135| | | |+|D7|BAS85|Schottky barrier diode|SOD80C|3|146-9394|0,23|BAS 85 SMD|0,034|771-BAS85135| | | |
 |D8|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | |D8|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | |
 |D9|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | |D9|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | |
-|D1|green|LED|LED_3MM|1|276-4976|0,409|LED 3MM ST GN| | | | | | +|D1|green|LED|LED_3MM|1|276-4976|0,409|LED 3MM ST GN| |710-151034GS03000| | | |
-|D2|red|LED|LED_3MM|1|276-4977|0,361|LED 3MM ST RT| | | | | | +|D2|red|LED|LED_3MM|1|276-4977|0,361|LED 3MM ST RT| |710-151034RS03000| | | |
-|D3|blue|LED|LED_3MM|1|276-4975|0,443|LED 3MM ST BL| | | | | | +|D3|blue|LED|LED_3MM|1|276-4975|0,443|LED 3MM ST BL| |710-151034BS03000| | | |
-|BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2,98| | | | |BU2032-1-ND|0,66| +|BAT1-HOLDER| |Battery Holder CR2032| |1|131-9749|2,98| | | | |BU2032-1-ND|0,66|
-|BAT1|CR2032P_L|Lithium  Battery 3,0Volt|CR_2032_H|1| | |CR 2032P-H| | | | | |+|BAT1|CR2032P_L|Lithium Battery 3,0Volt|CR_2032_H|1| | |CR 2032P-H| | | | | |
 |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0,81|USB AW|0,2| | | | | |X1|PN87520-S|USB Plug HOST|PN87520-S|1|117-7883|0,81|USB AW|0,2| | | | |
 |J11|MINI-USB_B|USB Plug DFU|MINI-USB_B|1|211-2367|0,561|USB BWM SMD|0,28| | | | | |J11|MINI-USB_B|USB Plug DFU|MINI-USB_B|1|211-2367|0,561|USB BWM SMD|0,28| | | | |
 |LCD1|HY32D|3,2 Zoll LCD ILI9325|HY32D_UHSDR_MOD|1| | | | | | | | | |LCD1|HY32D|3,2 Zoll LCD ILI9325|HY32D_UHSDR_MOD|1| | | | | | | | |
-|L1|47uH|L_SMD1005|L1005|3|221-5655|0,13| | | | |MLZ2012M470WT000|0,12|+|L1|47uH|L_SMD1005|L1005|3|221-5655|0,13| | |810-MLZ2012M470WT000| |MLZ2012M470WT000|0,12|
 |L2|47uH|L_SMD1005|L1005|.| | | | | | | | | |L2|47uH|L_SMD1005|L1005|.| | | | | | | | |
 |L3|47uH|L_SMD1005|L1005|.| | | | | | | | | |L3|47uH|L_SMD1005|L1005|.| | | | | | | | |
-|R1|47k|SMD Resistor TK50|0805|6| | |SMD-0805 47k|0,02| | | | | +|R1|47k|SMD Resistor TK50|0805|6| | |SMD-0805 47k|0,02|667-ERJ-U06F4702V| | | |
-|R1A|100R|SMD Resistor TK50|0603|13| | |SMD-0603 100|0,03| | | | | +|R1A|100R|SMD Resistor TK50|0603|13| | |SMD-0603 100|0,03|667-ERJ-3RBD1000V| | | |
-|R1B|0R|SMD Resistor TK50|0603|3| | |SMD-0603 0|0,03| | | | | +|R1B|0R|SMD Resistor TK50|0603|3| | |SMD-0603 0|0,03|667-ERJ-3GEY0R00V| | | |
-|R2|1k|SMD Resistor TK50|0603|7| | |SMD-0603 1,0k|0,03| | | | |+|R2|1k|SMD Resistor TK50|0603|7| | |SMD-0603 1,0k|0,03|667-ERJ-S03F1001V| | | |
 |R3|100R|SMD Resistor TK50|0603|.| | | | | | | | | |R3|100R|SMD Resistor TK50|0603|.| | | | | | | | |
 |R4|1k|SMD Resistor TK50|0603|.| | | | | | | | | |R4|1k|SMD Resistor TK50|0603|.| | | | | | | | |
-|R4B1|2R2|SMD Resistor TK50|1206|4| | |SMD ¼W 2,2|0,03| | | | |+|R4B1|2R2|SMD Resistor TK50|1206|4| | |SMD ¼W 2,2|0,03|71-CRCW12062R20FNEB| | | |
 |R4D|2R2|SMD Resistor TK50|1206|.| | | | | | | | | |R4D|2R2|SMD Resistor TK50|1206|.| | | | | | | | |
 |R5|0R|SMD Resistor TK50|0603|.| | | | | | | | | |R5|0R|SMD Resistor TK50|0603|.| | | | | | | | |
Line 51: Line 54:
 |R7|1k|SMD Resistor TK50|0603|.| | | | | | | | | |R7|1k|SMD Resistor TK50|0603|.| | | | | | | | |
 |R8|100R|SMD Resistor TK50|0603|.| | | | | | | | | |R8|100R|SMD Resistor TK50|0603|.| | | | | | | | |
-|R9|4k7|SMD Resistor TK50|0805|4| | |SMD-0805 4,7k|0,02| | | | | +|R9|4k7|SMD Resistor TK50|0805|4| | |SMD-0805 4,7k|0,02|667-ERJ-S06F4701V| | | |
-|R10|4k7|SMD Resistor TK50|0603|1| | |SMD-0603 4,7k|0,02| | | | |+|R10|4k7|SMD Resistor TK50|0603|1| | |SMD-0603 4,7k|0,02|667-ERJ-3EKF4701V| | | |
 |R11|4k7|SMD Resistor TK50|0805|.| | | | | | | | | |R11|4k7|SMD Resistor TK50|0805|.| | | | | | | | |
 |R12|4k7|SMD Resistor TK50|0805|.| | | | | | | | | |R12|4k7|SMD Resistor TK50|0805|.| | | | | | | | |
-|R13|47R|SMD Resistor TK50|0603|7| | |SMD-0603 47|0,03| | | | |+|R13|47R|SMD Resistor TK50|0603|7| | |SMD-0603 47|0,03|667-ERJ-3EKF47R0V| | | |
 |R14|47R|SMD Resistor TK50|0603|.| | | | | | | | | |R14|47R|SMD Resistor TK50|0603|.| | | | | | | | |
 |R15|1k|SMD Resistor TK50|0603|.| | | | | | | | | |R15|1k|SMD Resistor TK50|0603|.| | | | | | | | |
Line 65: Line 68:
 |R21|47R|SMD Resistor TK50|0603|.| | | | | | | | | |R21|47R|SMD Resistor TK50|0603|.| | | | | | | | |
 |R22|47R|SMD Resistor TK50|0603|.| | | | | | | | | |R22|47R|SMD Resistor TK50|0603|.| | | | | | | | |
-|R23|0R|SMD Resistor TK50|0805|8| | |SMD-0805 0|0,02| | | | | +|R23|0R|SMD Resistor TK50|0805|8| | |SMD-0805 0|0,02|667-ERJ-U060R00V| | | |
-|R24|680R|SMD Resistor TK50|0805|4| | |SMD-0805 680|0,02| | | | |+|R24|680R|SMD Resistor TK50|0805|4| | |SMD-0805 680|0,02|ERJ-6ENF6800V| | | |
 |R25|4k7|SMD Resistor TK50|0805|.| | | | | | | | | |R25|4k7|SMD Resistor TK50|0805|.| | | | | | | | |
 |R26|100R|SMD Resistor TK50|0603|.| | | | | | | | | |R26|100R|SMD Resistor TK50|0603|.| | | | | | | | |
Line 77: Line 80:
 |R33|100R|SMD Resistor TK50|0603|.| | | | | | | | | |R33|100R|SMD Resistor TK50|0603|.| | | | | | | | |
 |R34|100R|SMD Resistor TK50|0603|.| | | | | | | | | |R34|100R|SMD Resistor TK50|0603|.| | | | | | | | |
-|R35A|4R7|SMD Resistor TK50|1206|1| | |SMD ¼W 4,7|0,03| | | | |+|R35A|4R7|SMD Resistor TK50|1206|1| | |SMD ¼W 4,7|0,03|71-CRCW12064R70FNEB| | | |
 |R36|680R|SMD Resistor TK50|0805|.| | | | | | | | | |R36|680R|SMD Resistor TK50|0805|.| | | | | | | | |
 |R37|680R|SMD Resistor TK50|0805|.| | | | | | | | | |R37|680R|SMD Resistor TK50|0805|.| | | | | | | | |
Line 113: Line 116:
 |C10|100nF|SMD Chip Capacitor X7R|0603|63| | |X7R 0603FCF 100N|0,04| | | | | |C10|100nF|SMD Chip Capacitor X7R|0603|63| | |X7R 0603FCF 100N|0,04| | | | |
 |C11|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C11|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
-|C12|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|9| | |T494B 10U 16 |0,51| | | | | +|C12|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|9| | |T494B 10U 16|0,51| | | | |
-|C13|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | |+|C13|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
 |C14|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C14|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C15|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C15|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
-|C16|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | | +|C16|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
-|C17|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | |+|C17|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
 |C18|1uF|SMD Chip Capacitor NP0/COG|0603|8| | |NPO 0603 CE 1,0U|0,04| | | | | |C18|1uF|SMD Chip Capacitor NP0/COG|0603|8| | |NPO 0603 CE 1,0U|0,04| | | | |
 |C19|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | | |C19|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
 |C20|470nF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | | |C20|470nF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
 |C21|1nF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | | |C21|1nF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
-|C22|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | |+|C22|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
 |C23|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C23|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
-|C24|4.7uF|SMD Tantal-ELKO |TA-A   3,2 x 1,6|1| | |T491A 4,7U 16|0,04| | | | |+|C24|4.7uF|SMD Tantal-ELKO|TA-A 3,2 x 1,6|1| | |T491A 4,7U 16|0,04| | | | |
 |C25|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C25|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C26|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C26|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
Line 143: Line 146:
 |C39|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | |C39|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | |
 |C40|470nF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | | |C40|470nF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
-|C41|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | |+|C41|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
 |C42|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C42|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C43|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C43|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
Line 184: Line 187:
 |C79|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C79|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C80|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C80|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
-|C81|1uF |SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |+|C81|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
 |C82|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | | |C82|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
-|C83|1uF |SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |+|C83|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
 |C84|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C84|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C85|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C85|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
Line 200: Line 203:
 |C95|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C95|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C96|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | | |C96|220uF|SMD Alu-Elko 16V low ESR|E_SMD_0608|.| | | | | | | | |
-|C97|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | | +|C97|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
-|C98|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | |+|C98|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
 |C99|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C99|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C101|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C101|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
Line 208: Line 211:
 |C105|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C105|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C106|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C106|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
-|C107|1uF |SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |+|C107|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
 |C108|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | | |C108|1uF|SMD Chip Capacitor NP0/COG|0603|.| | | | | | | | |
-|C109|220pF|SMD Chip Capacitor NP0/COG|0603|1| | |NPO 0603AAF 220P |0,04| | | | | +|C109|220pF|SMD Chip Capacitor NP0/COG|0603|1| | |NPO 0603AAF 220P|0,04| | | | |
-|C111|10uF|SMD Tantal-ELKO 16V|TA-B   3,5 x 2,8|.| | | | | | | | |+|C111|10uF|SMD Tantal-ELKO 16V|TA-B 3,5 x 2,8|.| | | | | | | | |
 |C112|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C112|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C120|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | | |C120|220uF|SMD Tantal-ELKO 10V|TA-C|.| | | | | | | | |
Line 217: Line 220:
 |C122|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C122|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
 |C123|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | | |C123|100nF|SMD Chip Capacitor X7R|0603|.| | | | | | | | |
-|C124|8,2pF – 10pF|SMD Chip Capacitor|0603|2| | |NPO-G0603 10P |0,04| | | | |+|C124|8,2pF – 10pF|SMD Chip Capacitor|0603|2| | |NPO-G0603 10P|0,04| | | | |
 |C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | |C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | |
-|S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0,64| | | | |CKN10433CT-ND|0,55|+|S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0,64| | |611-KSC941JLFS| |CKN10433CT-ND|0,55|
 |S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | |S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | |
 |S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | |S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | |
Line 239: Line 242:
 |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | | |S18|not assigned yet|SMD Pushbutton KSC941J| |.| | | | | | | | |
-|J1|1503_07|Audio Plug 3,5mm|1503_07|3|121-7016|2,26|LUM 1503-07|0,59| | | | |+|J1|1503_07|Audio Plug 3,5mm|1503_07|3| |2,26|LUM 1503-07|0,59| | | | |
 |J2|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | | |J2|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | |
 |J3|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | | |J3|1503_07|Audio Plug 3,5mm|1503_07|.| | | | | | | | |
Line 252: Line 255:
 | |Button Cap|Cap white|BTNKSC980|10| | | | | | |CKN10427-ND|0,27| | |Button Cap|Cap white|BTNKSC980|10| | | | | | |CKN10427-ND|0,27|
-|JP1|30 Pin Board to Board|Pinheader-1X30|1X30|1| | |3x  40-polig| | | | | | +|JP1|30 Pin Board to Board|Pinheader-1×30|1×30|1| | |3x 40-polig| | | | | |
-|JP2|25 Pin Board to Board|Pinheader-1X25|1X25|1| | | | | | | | | +|JP2|25 Pin Board to Board|Pinheader-1×25|1×25|1| | | | | | | | |
-|JP3| 6 Pin Board to Board|Pinheader-1X06|1X06|4| | | | | | | | | +|JP3|6 Pin Board to Board|Pinheader-1×06|1×06|4| | | | | | | | |
-|P1|SW_12V|Pinheader-1X02|1X02|6| | | | | | | | | +|P1|SW_12V|Pinheader-1×02|1×02|6| | | | | | | | |
-|P2|Speaker left|Pinheader-1X02|1X02|.| | | | | | | | | +|P2|Speaker left|Pinheader-1×02|1×02|.| | | | | | | | |
-|P7|Speaker right|Pinheader-1X02|1X02|.| | | | | | | | | +|P7|Speaker right|Pinheader-1×02|1×02|.| | | | | | | | |
-|P6|DFU mode Jumper|Pinheader-1X02|1X02|.| | | | | | | | | +|P6|DFU mode Jumper|Pinheader-1×02|1×02|.| | | | | | | | |
-|JP8|DEBUG|Pinheader-1X06|1X06|.| | | | | | | | | +|JP8|DEBUG|Pinheader-1×06|1×06|.| | | | | | | | |
-|JP17|short S17|Pinheader-1X02|1X02|.| | | | | | | | | +|JP17|short S17|Pinheader-1×02|1×02|.| | | | | | | | |
-|JP5|ext. USB Host|Pinheader-1X04|1X04|2| | | | | | | | | +|JP5|ext. USB Host|Pinheader-1×04|1×04|2| | | | | | | | |
-|JP6|ext. USB DFU|Pinheader-1X04|1X04|.| | | | | | | | | +|JP6|ext. USB DFU|Pinheader-1×04|1×04|.| | | | | | | | |
-|JP4|ext. Audio|Pinheader-1X06|1X06|.| | | | | | | | | +|JP4|ext. Audio|Pinheader-1×06|1×06|.| | | | | | | | |
-|JP7|ext. Audio|Pinheader-1X06|1X06|.| | | | | | | | | +|JP7|ext. Audio|Pinheader-1×06|1×06|.| | | | | | | | |
-|P3|alternative Bridge Vbat|Pinheader-1X02|1X02|.| | | | | | | | | +|P3|alternative Bridge Vbat|Pinheader-1×02|1×02|.| | | | | | | | |
-|LCD1| |Pinheader-2x17|2x17|1| | | | | | | | | +|LCD1| |Pinheader-2×17|2×17|1| | | | | | | | |
-|LCD/PCB| |Holeheader low profile 2x17|BL 2X17G 2,54|1| | | | | | | | |+|LCD/PCB| |Holeheader low profile 2×17|BL 2X17G 2,54|1| | | | | | | | |
 |BU2|MOLEX_SD_49225-0821|MICROSD_Cardreader|Molex 503182-1853|1|176-4375|1,99| | | | |HR1942CT-ND|2,05| |BU2|MOLEX_SD_49225-0821|MICROSD_Cardreader|Molex 503182-1853|1|176-4375|1,99| | | | |HR1942CT-ND|2,05|
Line 274: Line 277:
 | |optional parts| | | | | | | | | | | | | |optional parts| | | | | | | | | | | |
 |D4|SS16SMA|Vishay General Semiconductor SS16|DIODE_SMA| | | | | | | | | | |D4|SS16SMA|Vishay General Semiconductor SS16|DIODE_SMA| | | | | | | | | |
-|IC9|CY15B104Q|SPI FRAM|SO08| | | | | | | | | | +|IC9|CY15B104Q|SPI FRAM|SO08| | | | | |727-CY15B104Q-SXI| | | |
-|IC11|SST25VF04B|SPI FLASH 2,7V, 4Mbit|SO08| | | |SST 25VF040B|0,97| | |SST25VF040B-50-4I-SAF-N|0,82|+|IC11|SST25VF04B|SPI FLASH 2,7V, 4Mbit|SO08| | | |SST 25VF040B|0,97|579-25VF040B504IS2AE| |SST25VF040B-50-4I-SAF-N|0,82|
  • en/projekte/ovi40-sdr/bom.txt
  • Last modified: 11.03.2018 10:51
  • by yd0rwo
