en:projekte:mchf:startseitemchf
Differences
Link to this comparison view
Next revision
Previous revision
en:projekte:mchf:startseitemchf [25.09.2017 10:11] – clarifying license of mcHF hardware df8oeen:projekte:mchf:startseitemchf [07.02.2018 06:05] (current) df9ts_user
Line 1: Line 1:
 +{{tag>english}}{{tag>publish}}
 {{ https://www.amateurfunk-sulingen.de/data/uploads/first_time_on_air-small.jpg }} {{ https://www.amateurfunk-sulingen.de/data/uploads/first_time_on_air-small.jpg }}
Line 7: Line 8:
 The technology used today is called SMD (Surface Mounted Devices). In this case, the components are soldered directly to the conductor tracks of the circuit board: no "holes" with "pads", no wires to the components. This production technique is many levels less costly, the parts far smaller resulting in a reduction of resource usage, weight, assembly time and packaging cost.  The technology used today is called SMD (Surface Mounted Devices). In this case, the components are soldered directly to the conductor tracks of the circuit board: no "holes" with "pads", no wires to the components. This production technique is many levels less costly, the parts far smaller resulting in a reduction of resource usage, weight, assembly time and packaging cost.
-We got off the I40. The world's most advanced technology is the world's most advanced technology, and it is the world's most advanced technology. ?+We got off the I40 . The world's most advanced technology is the world's most advanced technology, and it is the world's most advanced technology. ?
 The DIY of such technology is a challenge - but at the same time an enormous ego. Microcontrollers, SMD technology: With the scale of today's parts everything is not possible. The DIY of such technology is a challenge - but at the same time an enormous ego. Microcontrollers, SMD technology: With the scale of today's parts everything is not possible.
  • en/projekte/mchf/startseitemchf.1506334318.txt.gz
  • Last modified: 25.09.2017 10:11
  • by df8oe
