Differences
en:ovi40wiki:wikihowto [27.01.2018 07:53] – df9ts_user | en:ovi40wiki:wikihowto [12.02.2018 14:02] (current) – df9ts | ||
Line 1: | Line 1: | ||
{{tag> | {{tag> | ||
===== OVI40 Wiki - Quick Guide ===== | ===== OVI40 Wiki - Quick Guide ===== | ||
=== Multi-language Wiki === | === Multi-language Wiki === | ||
The OVI40 is set up as multi-language Wiki. Each language have their separate [[https:// | The OVI40 is set up as multi-language Wiki. Each language have their separate [[https:// | ||
To summarise: | To summarise: | ||
* Check first if the page / topic that interests you exists in your language (explanation below) | * Check first if the page / topic that interests you exists in your language (explanation below) | ||
* If not: use Wiki automatic translation | * If not: use Wiki automatic translation | ||
Line 11: | Line 14: | ||
You may select your language here: | You may select your language here: | ||
While reading a Wiki page you may also use this menu to select the same Wiki page in a different language. If the page exists in another language the language will be in black text. If it does not exist it will be gray. By clicking on a greyed language you may create this page. | While reading a Wiki page you may also use this menu to select the same Wiki page in a different language. If the page exists in another language the language will be in black text. If it does not exist it will be gray. By clicking on a greyed language you may create this page. | ||
Line 18: | Line 22: | ||
=== Automatic Translation === | === Automatic Translation === | ||
- | Certain pages may only exist in certain languages. The Wiki pages in certain languages may contain more informations than in other languages. | + | |
- | For your convenience the OVI40 provides also automatic translation of Wiki pages: | + | Certain pages may only exist in certain languages. The Wiki pages in certain languages may contain more informations than in other languages. For your convenience the OVI40 provides also automatic translation of Wiki pages: |
=== General Information on the Wiki === | === General Information on the Wiki === | ||
- | * [[https:// | ||
+ | * [[https:// | ||
