en:ovi40wiki:wikihowto
Differences
Link to this comparison view
Next revision
Previous revision
en:ovi40wiki:wikihowto [26.01.2018 09:26] – created df9tsen:ovi40wiki:wikihowto [12.02.2018 14:02] (current) df9ts
Line 1: Line 1:
-{{tag>review}}+{{tag>english}}{{tag>publish}}
 ===== OVI40 Wiki - Quick Guide ===== ===== OVI40 Wiki - Quick Guide =====
 === Multi-language Wiki === === Multi-language Wiki ===
 The OVI40 is set up as multi-language Wiki. Each language have their separate [[https://www.dokuwiki.org/namespaces|namespace]]. The OVI40 is set up as multi-language Wiki. Each language have their separate [[https://www.dokuwiki.org/namespaces|namespace]].
 +To summarise:
 +  * Check first if the page / topic that interests you exists in your language (explanation below)
 +  * If not: use Wiki automatic translation
 +  * It may be interesting - even if the page exists in your language - to check the same page in other languages since the content may differ and contain additional information. Use automatic translation if needed.
 You may select your language here: You may select your language here:
-[{{:ovi40wiki:languagebar.png?200|Multi-language selection in OVI40 Wiki}}]+
 +[{{:ovi40wiki:languagebar.png?400|Multi-language selection in OVI40 Wiki}}]
 While reading a Wiki page you may also use this menu to select the same Wiki page in a different language. If the page exists in another language the language will be in black text. If it does not exist it will be gray. By clicking on a greyed language you may create this page. While reading a Wiki page you may also use this menu to select the same Wiki page in a different language. If the page exists in another language the language will be in black text. If it does not exist it will be gray. By clicking on a greyed language you may create this page.
Line 13: Line 22:
 === Automatic Translation === === Automatic Translation ===
-Certain pages may only exist in certain languages. The Wiki pages in certain languages may contain more informations than in other languages.  +
-For your convenience the OVI40 provides also automatic translation of Wiki pages:  +Certain pages may only exist in certain languages. The Wiki pages in certain languages may contain more informations than in other languages. For your convenience the OVI40 provides also automatic translation of Wiki pages:
 [{{:ovi40wiki:googletranslate.png?400|Automatic Translation}}] [{{:ovi40wiki:googletranslate.png?400|Automatic Translation}}]
 === General Information on the Wiki === === General Information on the Wiki ===
-  * [[:wiki:welcome]]
-  * [[https://www.dokuwiki.org/en:manual]]
-  * [[https://www.dokuwiki.org/wiki:syntax]]
-  * [[https://www.dokuwiki.org/plugin:bootnote]]
 +  * [[:wiki:welcome|]]
 +  * [[https://www.dokuwiki.org/en:manual|https://www.dokuwiki.org/en:manual]]
 +  * [[https://www.dokuwiki.org/wiki:syntax|https://www.dokuwiki.org/wiki:syntax]]
 +  * [[https://www.dokuwiki.org/plugin:bootnote|https://www.dokuwiki.org/plugin:bootnote]]
  • en/ovi40wiki/wikihowto.txt
  • Last modified: 12.02.2018 14:02
  • by df9ts
