Both sides previous revision Previous revision | |
en:ovi40what:ovi40_specs [07.02.2018 06:02] – df9ts_user | en:ovi40what:ovi40_specs [07.02.2018 06:45] (current) – removed df9ts_user |
{{tag>english}}{{tag>stub}} | |
===== OVI40 Specifications ===== | |
UI board, table of features: | |
|PCB form factor: |186mm x 66mm | | |
|processor: |STM32F76x, optional STM32H743 (144pin LQFP) | | |
|audio codec: |2 x WM8731 @ 96KHz (actually firmware supports 48KHz), IQ and audio seperated, (simultaneously TX and RX possible, if RF board supports it) | | |
|display: |3.5" 480×320, supporting more LCDs later | | |
|LCD interface: |parallel / SPI | | |
|internal memory: |SPI-Flash (optional), SPI-RAM (optional) | | |
|external memory: |microSD Card | | |
|real time clock: |integrated RTC of STM32, CR2032 backup battery | | |
|LEDs: |3 | | |
|external connectors: |Mini-USB Type B, USB-Host (USB-A), 3.5mm microphone and PTT, 3.5mm Stereo analog in, 3.5mm Stereo analog out (speaker independent), 3.5mm Stereo audio uut (headphones) | | |
|internal connectors: |30pin pinheader (mcHF compatible) +6pin GPIO, 25pin pinheader (div. GPIOs, SPI, I2C), STLinkV2 compatible connector, debug print, 2 x 4pin internal USB connectors | | |
|buttons:|18 independent | | |
|encoders:|4, with independent push functions | | |
|audio output stage: |stereo, 2x3W | | |
30pin header J1 is downcompatible to [[http://www.m0nka.co.uk/|mcHF]] rf PCB so that you can use OVI40-UI in bundle with mcHF rf (version <= 0.6). Of course only features which are supported by this rf PCB will be available. | |
