Differences
en:ovi40build:uiboardbuild [03.02.2018 10:42] – [Modifications] Disco F746 added df9ts_user | en:ovi40build:uiboardbuild [11.02.2018 16:06] – [Assembly and Soldering] df9ts_user | ||
Line 16: | Line 16: | ||
- | * [[: | + | * [[en: |
Line 82: | Line 82: | ||
This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | ||
**Do not solder in R101** for the EEPROM delivered with the kit (AT24CM02). | **Do not solder in R101** for the EEPROM delivered with the kit (AT24CM02). |
