Differences
en:ovi40build:uiboardbuild [27.01.2018 07:03] – df9ts_user | en:ovi40build:uiboardbuild [19.02.2018 18:20] – df9ts | ||
Line 16: | Line 16: | ||
==== OVI40 UI V1.8 Kit Contents ==== | ==== OVI40 UI V1.8 Kit Contents ==== | ||
Line 36: | Line 36: | ||
=== Please read Errata carefully === | === Please read Errata carefully === | ||
- | Make sure to read the [[: | + | Make sure to read the [[en: |
Line 82: | Line 82: | ||
This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | ||
+ | **Do not solder in R101** for the EEPROM delivered with the kit (AT24CM02). | ||
=== Prevent short cut with back up battery holder === | === Prevent short cut with back up battery holder === | ||
Line 101: | Line 105: | ||
"In line" is the preferred mounting location for S7 and S8. | "In line" is the preferred mounting location for S7 and S8. | ||
+ | === IC9 und IC11: leave empty for now === | ||
+ | IC9 (SPI FRAM) and IC11 (SPI FLASH) are for future use. Please leave empty for now. They are neither required nor supported by UHSDR at this time. | ||
+ | === STM32F76xxx === | ||
+ | * 0x000: Reserved | ||
+ | * 0101: TQFP176/ | ||
+ | * 1000: LQFP208/ | ||
==== Modifications ==== | ==== Modifications ==== | ||
Line 106: | Line 130: | ||
=== Temporary Modification: | === Temporary Modification: | ||
- | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: | + | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: |
=== Change brightness of LEDs === | === Change brightness of LEDs === |
