Differences
en:ovi40build:uiboardbuild [25.01.2018 07:57] – df9ts | en:ovi40build:uiboardbuild [02.03.2018 18:13] (current) – df9ts_user | ||
Line 1: | Line 1: | ||
- | {{tag> | + | ==== Modifications ==== |
- | ===== Building the UI V1.8 Board ===== | + | === Temporary Modification: |
- | ==== OVI40 UI V1.8 Kit Contents ==== | + | Symptom: In stand-by the current drawn from back-up battery is excessively high. Work-around: |
- | The kit contains UI V1.8 PCB, components in bags and packing list. The display is delivered as assembled and tested unit. | + | === Change brightness of LEDs === |
- | |[{{:projekte: | + | Helle LEDS: Mit den Bausatz-Vorwiderständen leuchten die LEDs sehr hell. DF9EH hat die Werte reduziert: |
- | ==== Assembly and Soldering ==== | ||
- | The graphics below - UI V1.7 with 3.2" Display - give an impression on how the finished V1.8 UI board will look like: | ||
- | |< 95% 50% 50% >| | ||
- | === Please read Errata carefully === | ||
- | Make sure to read the [[: | ||
- | === IC Device Markings === | ||
- | The smaller ICs can be identified by device mark. The following device marks are used: | ||
- | |< 45% 25% 25% 25% 25% >| | ||
- | |Typ |Device Mark |Schematic | ||
- | |LP5907_Q1 | ||
- | |BAV70 | ||
- | |BC857B | ||
- | |BAS85 | ||
- | === MCU STM32 "Pin 1" marking === | ||
- | Please understand the correct orientation of STM32 MCU Pin 1. There are two markings on the IC. | ||
- | Please not the text printed on MCU to find the correct Pin 1: When reading the text Pin 1 is on bottom left corner. | ||
- | === Prevent short cut with back up battery holder === | ||
- | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** - see photo: | ||
- | === Polarised capacitors === | ||
- | Please observe mounting orientation of tantal and electrolytic capacitors. Markings on the capacitors are explained [[http:// | ||
- | === MCU Pin 1 marking ambigious === | ||
- | die MCU hat zwei (!) Pin 1 Markierungen | ||
- | === Temporäre Modifikation: | ||
- | Symptom: Bei ausgeschaltetem UI Board wird durch die MCU zuviel Strom us der Lithium Batterie verbraucht. | ||
- | Temporäre Lösung: Parallel zu C94 einen Widerstand löten, Widerstandswert zwischen 47k und 100k (abhängig je MCU, Exemplarstreuung. Bei 47k bootet die MCU nicht bei allen Exemplaren zuverlässig. Wird der Wert zu hoch gewählt dann tritt der Effekt des hohen Stromverbrauchs bei Poweroff auf. Ein Wert von 56k scheint generell zu funktionieren. | ||
- | **Das Problem wird weiterhin analysiert, die Modifikation ist nur eine temporäre Lösung.** | ||
- | === Taster S7 und S8 === | ||
- | Taster S7 und S8 können in 2 möglichen Positionen eingelötet werden: | ||
- | * "old mcHF style", | ||
- | * "in einer Reihe" mit den F-Tasten. Letzteres ist vorgesehen für die später mal folgende Option, ein wesentlich größeres Display (5" ?? 7" ??) anzubringen, | ||
- | ==== Unterlagen: OVI40 UI V1.7 ==== | ||
- | UI V1.7 war die Beta Test Version der UI Platine. Es bestehen nur wenige Unterschiede zwischen V1.7 und V1.8 (der ausgelieferten Bausatz Platine). Die V1.7 Unterlagen sind deshalb interessant zum Vergleich und als Ergänzung. | ||
- | OVI40 UI V1.7 Schaltbild: {{: | ||
- | OVI40 UI PCB bottom layer: {{: | ||
- | OVI40 UI PCB top layer: {{: | ||
- | ==== Unterlagen: OVI40 UI V1.8 ==== | ||
- | Im Vergleich zur V1.7 UI kommt bei der UI V1.8 folgendes dazu: | ||
- | * unter dem Display ein weiterer zusätzlicher Taster | ||
- | * die beiden STEP Taster unterm VFO können in zwei verschiedenen Positionen eingelötet werden. Entweder klassisch leicht nach oben versetzt wie beim mcHF oder tiefer und damit in einer Flucht mit den 6 Funktionstasten. | ||
- | BoM von F4HTX Francois mit Bauteiletütchen Nummern: {{: | ||
- | ==== STM32F76X_ZIT vs. STM32H743ZIT6 ==== | ||
- | Der Bausatz enthält den STM32F76X_ZIT. Der neue STM32H743ZIT6 kann eingesetzt werden, wird aber nicht mitgeliefert. Die H7 - MCU wird zukünftig der Standard sein, die F7 MCU wird " | ||
- | |< 90% 25% 25% 25% 25% >| | ||
- | |Flash[kB] | ||
- | |Takt[MHz] | ||
- | |FPU |single | ||
- | |Pins |100 |144 |144 | | ||
- | |DMIPS | ||
- | ==== Die UI-Platine in Betrieb nehmen ==== | ||
- | Die UI-Platine kann (und sollte) ohne die RF-Platine zum ersten Mal in Betrieb genommen werden. Lasst das LCD zunächst weg, Jumper P6 wird gesteckt. An Pin 30 des oberen Headers (JP1) wird Masse gelegt, an Pin28 von JP1 wird +5V. Die Stromaufnahme in diesem Zustand liegt deutlich unter 80mA. Wenn nicht: Betriebsspannung sofort wieder trennen und Fehler suchen! Wenn alles ok ist, verbindet ihr die kleine USB-Buchse mit einem PC. Dieser sollte eine neue Hardwarekomponente finden (Windows) - bei Linux kann man auf der Kommandozeile mit \\ //dfu-util -l// \\ schauen, ob der STM32F7 angesprochen werden kann. Wenn ja, kann man die Software unter Linux nun flashen mit | ||
- | Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | ||
- | Firmware: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | ||
- | Unter Windows macht man das gleiche mit dem Tool "DfuSE Demo" von STM. \\ [[https:// | ||
- | xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx | ||
- | {{tag> | ||
- | ===== UI Board Test & Fehlersuche ===== | ||
- | ==== EEPROM IC7 Einbau Lage ==== | ||
- | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | ||
- | Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike the mcHF. | ||
- | Typischer Stromverbrauch: | ||
- | Flashprobleme: | ||
- | * Uhrenquarz und TCXO sind für das Flashen beide absolute Voraussetzung. | ||
- | * Bitte genau prüfen ob der TCXO richtig herum eingelötet ist! | ||
- | * wenn die 3V3 am C95 nicht mehr anliegen ist L3 wohl defekt | ||
- | Helle LEDS: Mit den Bausatz-Vorwiderständen leuchten die LEDs sehr hell. DF9EH hat die Werte reduziert: | ||
