Differences
en:ovi40build:uiboardbuild [25.01.2018 07:57] – df9ts | en:ovi40build:uiboardbuild [19.02.2018 18:20] – df9ts | ||
Line 1: | Line 1: | ||
- | {{tag>stub}} | + | {{tag>english}}{{tag> |
===== Building the UI V1.8 Board ===== | ===== Building the UI V1.8 Board ===== | ||
+ | ==== OVI40 UI V1.7 Documents ==== | ||
+ | **UI V1.7 documents are provided for information only**. Please primarily use the V1.8 documents for building the UI V1.8 board. | ||
+ | Please note that the component placement docs are searchable pdf documents. During soldering they can be used to quickly find a component' | ||
+ | ==== OVI40 UI V1.8 Documents ==== | ||
+ | * [[en: | ||
==== OVI40 UI V1.8 Kit Contents ==== | ==== OVI40 UI V1.8 Kit Contents ==== | ||
Line 7: | Line 23: | ||
The kit contains UI V1.8 PCB, components in bags and packing list. The display is delivered as assembled and tested unit. | The kit contains UI V1.8 PCB, components in bags and packing list. The display is delivered as assembled and tested unit. | ||
- | |[{{: | + | |< 60% 33% 33% 33% >| |
==== Assembly and Soldering ==== | ==== Assembly and Soldering ==== | ||
The graphics below - UI V1.7 with 3.2" Display - give an impression on how the finished V1.8 UI board will look like: | The graphics below - UI V1.7 with 3.2" Display - give an impression on how the finished V1.8 UI board will look like: | ||
=== Please read Errata carefully === | === Please read Errata carefully === | ||
- | Make sure to read the [[: | ||
- | === IC Device Markings === | + | Make sure to read the [[en: |
The smaller ICs can be identified by device mark. The following device marks are used: | The smaller ICs can be identified by device mark. The following device marks are used: | ||
|LP5907_Q1 | |LP5907_Q1 | ||
Line 29: | Line 53: | ||
=== MCU STM32 "Pin 1" marking === | === MCU STM32 "Pin 1" marking === | ||
- | Please understand the correct orientation of STM32 MCU Pin 1. There are two markings on the IC. | ||
- | Please not the text printed on MCU to find the correct Pin 1: When reading the text Pin 1 is on bottom left corner. | ||
- | === Prevent short cut with back up battery holder === | + | Please understand |
- | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** - see photo: | + | |
- | === Polarised capacitors === | + | [{{:projekte:ovi40-sdr: |
- | Please observe mounting orientation of tantal and electrolytic capacitors. Markings on the capacitors are explained | + | |
- | === MCU Pin 1 marking ambigious | + | < |
- | die MCU hat zwei (!) Pin 1 Markierungen | + | |
+ | The kit is shipped with STM32F76X_ZIT (" | ||
+ | Comparison of MCUs: | ||
+ | |Flash[kB] | ||
+ | |Clock[MHz] | ||
+ | |FPU |single | ||
+ | |DMIPS | ||
+ | === EEPROM IC7 orientation === | ||
+ | **Do not solder in R101** for the EEPROM delivered with the kit (AT24CM02). | ||
+ | === Prevent short cut with back up battery holder === | ||
+ | One of the connection pins of the battery holder might touch ground connection of a rotary encoder. Make sure to cut this pin flush with PCB surface **before soldering** | ||
- | === Temporäre Modifikation: Resistor in parallel to C94 === | + | [{{:projekte:ovi40-sdr: |
- | Symptom: Bei ausgeschaltetem UI Board wird durch die MCU zuviel Strom us der Lithium Batterie verbraucht. | + | |
- | Temporäre Lösung: Parallel zu C94 einen Widerstand löten, Widerstandswert zwischen 47k und 100k (abhängig je MCU, Exemplarstreuung. Bei 47k bootet die MCU nicht bei allen Exemplaren zuverlässig. Wird der Wert zu hoch gewählt dann tritt der Effekt des hohen Stromverbrauchs bei Poweroff auf. Ein Wert von 56k scheint generell zu funktionieren. | + | |
- | **Das Problem wird weiterhin analysiert, die Modifikation ist nur eine temporäre Lösung.** | + | |
- | === Taster S7 und S8 === | + | === Polarised capacitors |
- | * "old mcHF style", | + | Please observe mounting orientation of tantal and electrolytic capacitors. Markings on the capacitors are explained [[http:// |
- | * "in einer Reihe" mit den F-Tasten. Letzteres ist vorgesehen für die später mal folgende Option, ein wesentlich größeres Display (5" ?? 7" ??) anzubringen, | + | |
- | ==== Unterlagen: OVI40 UI V1.7 ==== | + | === Mounting locations of switches S7 and S8 === |
- | UI V1.7 war die Beta Test Version der UI Platine. Es bestehen nur wenige Unterschiede zwischen V1.7 und V1.8 (der ausgelieferten Bausatz Platine). Die V1.7 Unterlagen sind deshalb interessant zum Vergleich und als Ergänzung. | + | Two different mounting locations are provided on the UI PCB for S7 and S8: |
- | < | + | * "mcHF style": S7 and S8 not line with switches under LCD - they are mounted slightly higher |
+ | * "OVI40 style": | ||
- | OVI40 UI V1.7 Schaltbild: {{: | + | "In line" is the preferred mounting location for S7 and S8. |
- | OVI40 UI PCB bottom layer: {{: | + | === IC9 und IC11: leave empty for now === |
+ | IC9 (SPI FRAM) and IC11 (SPI FLASH) are for future use. Please leave empty for now. They are neither required nor supported by UHSDR at this time. | ||
- | OVI40 UI PCB top layer: {{:projekte:ovi40-sdr:uhsdr_ui_ovi40_bst_top_layer_17.pdf|uhsdr_ui_ovi40_bst_top_layer_17.pdf}} | + | ==== Device Electronic Signature ==== |
+ | === STM32F76xxx === | ||
+ | * 0x000: Reserved | ||
+ | * 0101: TQFP176/ | ||
+ | * 1000: LQFP208/ | ||
- | ==== Unterlagen: OVI40 UI V1.8 ==== | + | ==== Modifications |
- | BoM von F4HTX Francois mit Bauteiletütchen Nummern: {{: | + | |
- | ==== STM32F76X_ZIT vs. STM32H743ZIT6 ==== | + | |
- | Der Bausatz enthält den STM32F76X_ZIT. Der neue STM32H743ZIT6 kann eingesetzt werden, wird aber nicht mitgeliefert. Die H7 - MCU wird zukünftig der Standard sein, die F7 MCU wird " | + | |
- | Hier mal ein kurzer Vergleich: | + | |
- | |< 90% 25% 25% 25% 25% >| | + | |
- | |Flash[kB] | + | |
- | |RAM [kB] |192 |512 |1024 | | + | |
- | |Takt[MHz] | + | |
- | |FPU |single | + | |
- | |Pins |100 |144 |144 | | + | |
- | |DMIPS | + | |
- | ==== Die UI-Platine in Betrieb nehmen ==== | + | |
- | Die UI-Platine kann (und sollte) ohne die RF-Platine zum ersten Mal in Betrieb genommen werden. Lasst das LCD zunächst weg, Jumper P6 wird gesteckt. An Pin 30 des oberen Headers (JP1) wird Masse gelegt, an Pin28 von JP1 wird +5V. Die Stromaufnahme in diesem Zustand liegt deutlich unter 80mA. Wenn nicht: Betriebsspannung sofort wieder trennen und Fehler suchen! Wenn alles ok ist, verbindet ihr die kleine USB-Buchse mit einem PC. Dieser sollte eine neue Hardwarekomponente finden (Windows) - bei Linux kann man auf der Kommandozeile mit \\ //dfu-util -l// \\ schauen, ob der STM32F7 angesprochen werden kann. Wenn ja, kann man die Software unter Linux nun flashen mit | + | |
- | Bootloader: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | + | |
- | Firmware: //dfu-util -d -R -a 0 0483:df11 -D Pfad-zur/ | + | |
- | Unter Windows macht man das gleiche mit dem Tool "DfuSE Demo" von STM. \\ [[https:// | + | |
- | Wenn der Vorgang erfolgreich war, trennt man die Betriebsspannung wieder, entfernt den Jumper P6, steckt das LCD in seine Fassung und legt die Betriebsspannung wieder an. Die Firmware sollte nun booten (klar: mit Fehlermeldungen - weil keine RF-Platine dran ist) und sich mit dem bekannten UHSDR-Bildschirm melden. | + | |
- | xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx | + | |
- | {{tag> | + | |
- | ===== UI Board Test & Fehlersuche ===== | + | |
- | ==== EEPROM IC7 Einbau Lage ==== | + | |
- | This is where the dot is printed. Also the edge of the case is slanted near the 1-4 pins. See [[http:// | + | |
- | Im falle von fehlendem Audio out: just in case, please check the SW_12V connection. This is power supply connector for Audio power amplifier stage unlike | + | Symptom: In stand-by |
- | Typischer Stromverbrauch: | + | === Change brightness of LEDs === |
- | Flashprobleme: | + | Helle LEDS: Mit den Bausatz-Vorwiderständen leuchten die LEDs sehr hell. DF9EH hat die Werte reduziert: |
- | * Uhrenquarz und TCXO sind für das Flashen beide absolute Voraussetzung. | + | |
- | * Bitte genau prüfen ob der TCXO richtig herum eingelötet ist! | + | |
- | * wenn die 3V3 am C95 nicht mehr anliegen ist L3 wohl defekt | + | |
- | Helle LEDS: Mit den Bausatz-Vorwiderständen leuchten die LEDs sehr hell. DF9EH hat die Werte reduziert: | ||
