Differences
en:ovi40_batch1uiboarderrata [14.01.2018 08:27] – [Other] df9ts | en:ovi40build:ovi40_batch1uiboarderrata [16.01.2018 22:52] – ↷ Page moved from en:ovi40_batch1uiboarderrata to en:ovi40build:ovi40_batch1uiboarderrata df9ts | ||
Line 5: | Line 5: | ||
===== In Kit Bag 1 ===== | ===== In Kit Bag 1 ===== | ||
- | * 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes</ | + | * 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes |
* Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788) | * Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788) | ||
* The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in | * The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in |
