Differences
en:ovi40_batch1uiboarderrata [14.01.2018 08:26] – [Errata for OVI40 Batch 1 kit delivery] df9ts | en:ovi40build:ovi40_batch1uiboarderrata [07.02.2018 05:59] (current) – df9ts_user | ||
Line 1: | Line 1: | ||
====== Errata for OVI40 UI V1.8 Batch 1 kit delivery ====== | ====== Errata for OVI40 UI V1.8 Batch 1 kit delivery ====== | ||
Line 5: | Line 6: | ||
===== In Kit Bag 1 ===== | ===== In Kit Bag 1 ===== | ||
- | * 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes</ | + | * 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes |
* Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788) | * Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788) | ||
* The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in | * The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in | ||
Line 19: | Line 20: | ||
* The capacitors (8, | * The capacitors (8, | ||
- | ==== Other ==== | + | ===== Other ===== |
* R2, R6, R7, R10-12,R15, R25, R40 have 0603 footprint in BOM but on PCB we have 0805. Can still be soldered in | * R2, R6, R7, R10-12,R15, R25, R40 have 0603 footprint in BOM but on PCB we have 0805. Can still be soldered in | ||
* C100 is marked “COO” (letter " | * C100 is marked “COO” (letter " | ||
