Next revision | Previous revisionLast revisionBoth sides next revision |
en:ovi40_batch1uiboarderrata [14.01.2018 08:17] – created df9ts | en:ovi40build:ovi40_batch1uiboarderrata [16.01.2018 22:52] – ↷ Page moved from en:ovi40_batch1uiboarderrata to en:ovi40build:ovi40_batch1uiboarderrata df9ts |
====== Errata for OVI40 Batch 1 kit delivery ====== | ====== Errata for OVI40 UI V1.8 Batch 1 kit delivery ====== |
<font 9.0pt/inherit;;black;;inherit>Source:</font> | |
| Source: |
[[https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=935;start=0|https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=935;start=0]] | [[https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=935;start=0|https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=935;start=0]] |
===== \\ | ===== In Kit Bag 1 ===== |
<font 9.0pt/inherit;;black;;inherit>**In Kit Bag 1:**</font> ===== | * 3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes |
| * Cut the plastic noses or use fitting socket Lumberg 1503-7 (Reichelt LUM 1503-07, Conrad 738788) |
| * The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Layout and BoM. Can still be soldered in |
* | ===== In Kit Bag 2: ===== |
| * Mini-USB socket J11 is “Type A” but “Type B” is required. Use correct socket, e.g. Buerklin 72F2280 |
<font 9.0pt/inherit;;black;;inherit>3.5 mm Stereo Connectors J1, J2, J3 plastic noses won’t fit the PCB holes</font> | ===== In Kit Bag 4: ===== |
| * The 2.2 uF capacitors have size 0805, but size 0603 is required in BoM and PCB Layout. Can still be soldered in. |
* | ===== Kit Bag 5: ===== |
| * The 1 uF capacitors are 1206, but 0603 is required according to BoM. Need to get correct size, e.g. 0603, e.g. Buerklin 75D5307 |
| * The capacitors (8,2pF-10pF) are 0402 but should be 0603. Can still be soldered in. |
<font 9.0pt/inherit;;black;;inherit>Cut the plastic noses</font> <font 9.0pt/inherit;;black;;inherit>or u</font> <font 9.0pt/inherit;;black;;inherit>se fitting socket</font> **<font 9.0pt/inherit;;inherit;;inherit>Lumberg 1503-7 (Reichelt</font>** <font 9.0pt/inherit;;black;;white>LUM 1503-07, Conrad</font> <font 9.0pt/inherit;;black;;inherit>738788)</font> | ===== Other ===== |
| * R2, R6, R7, R10-12,R15, R25, R40 have 0603 footprint in BOM but on PCB we have 0805. Can still be soldered in |
* | * C100 is marked “COO” (letter "O" instead of digit "0") instead in schematics (so can’t be found with Acrobat Reader in schematic |
<font 9.0pt/inherit;;black;;inherit>The 470 nF capacitors have size 0805, however size 0603 is required according to PCB Laout and BoM. Can still be soldered in</font> | |
===== In Kit Bag 2: ===== | |
* <font 9.0pt/inherit;;black;;inherit>Mini-USB socket J11 is “Type A” but “Type B” is required.</font> <font 9.0pt/inherit;;black;;inherit>Use correct socket, e.g. Buerklin</font> <font 9.0pt/inherit;;inherit;;inherit>72F2280</font> | |
===== In Kit Bag 4: ===== | |
* <font 9.0pt/inherit;;black;;inherit>The 2.2 uF capacitors have size 0805, but size 0603 is required in BoM and PCB Layout. Can still be soldered in.</font> | |
===== Kit Bag 5: ===== | |
* <font 9.0pt/inherit;;black;;inherit>The 1 uF capacitors are 1206, but 0603 is required according to BoM.</font> * <font 9.0pt/inherit;;black;;inherit>Use correct size 0603, e.g. Buerklin 75D5307</font> | |
\\ <font 9.0pt/inherit;;black;;inherit>**Kit Bag 6:**</font> \\ | |
* <font 9.0pt/inherit;;black;;inherit>The capacitors (8,2pF-10pF) are 0402 but should be 0603.</font> * <font 9.0pt/inherit;;black;;inherit>Solder in</font> | |
<font 9.0pt/inherit;;black;;inherit>**Other:</font> ** | |
* <font 9.0pt/inherit;;black;;inherit>R2, R6, R7, R10-12,R15, R25, R40 have 0603 footprint in BOM but on PCB we have 0805.</font> | |
* <font 9.0pt/inherit;;black;;inherit>C100 is marked “COO” instead in schematics (so can’t be found with Acrobat Reader “find”</font> | |
<font 10.5pt/inherit;;inherit;;inherit>Errata OVI40 UI Board V1.8 Batch 1</font> | |
[[https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=935;start=0|https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=935;start=0]] | |
