Differences
Both sides previous revision Previous revision | Next revisionBoth sides next revision | ||
en:ovi40build:displaybuild [18.02.2018 13:58] – df9ts | en:ovi40build:displaybuild [18.02.2018 14:04] – Include forum post F4HTX df9ts | ||
Line 87: | Line 87: | ||
- | \\ | + | ==== On shortening the male header J103 on OVI40 UI for LCD display ==== |
+ | Cutting the male header pins pf J103 (on component side) is required to reduce height of the LCD Display module above OVI40 UI PCB. Cutting / shortening the pins on component | ||
+ | An alternative is to solder the pins at the right depth and then cut the pins flush to the pcb on the solder side. | ||
