Display Board Building
3.5" is the OVI40-SDR standard default display
The 3.5 inch LCD panel has exactly the same outer dimensions as the PCB porting plate of the previous 3.2 inch display. The key switches S7 and S8 on the UI board need to be mounted in the “lower” positions (i.e. in line with the function keys below LCD), in order not to be in the way.
Display Board
The display board plugs into UI board vonnector directly. The display board contains LCD display and touch panel functionality. For mechanical mounting oDie Displayplatine beinhaltet Display und Touchpanel. For mechanical mounting considerations please see below.
The following LCDs can be used with UI board V1.8 and UHSDR:
- 3.5“ display 480×320 with controller ILI9846 (ot ILI9846 compatible controller): OVI40 default display
- 3.2” display 320 x 240 witch controller IL9325 (or IL9325 compatible controller): this was the display used during UI V1.8 beta testing
- 2.8“ display 320 x 240 with controller IL9325 (or compatible controller): this is the mcHF defult display
|< 95% 50% 50% >|
Display Calibration - mandatory at first bring-up
Important: It is mandatory to do a display calibration at first bring-up / switch on of the touch screen display. Only after calibration will the touch screen work with UHSDR.
Start the calibration by touching the touch screen with a finger before switching on the UI board V1.8. Keep touching the touch screen until the service menu sis displayed. Now release the finger from the touch screen and follow instructions on the screen carefully. After calibration is finished please save the calibration by long-pressing the “menu” button switch on the UI board, then long-press “power” button.
Mechanical fixing of the display board onto the UI board
The display board will be mechanically held in position by the casing. As long as the casing is not available yet, a temporary solution is required.
Simple approach: a piece of non-conductive material (e.g. plastic) of suitable height can be fixed between UI board and LCD PCB with double-sided self-adhesive tape. This will keep the display board stabilized and away from the UI board.
Just make sure that it is still possible to easy unplugging of the display board is still possible, when needed.
Alternatively plastic spacer bolts may be used:
Option 1 plastic spacer Plastik-Abstandshalter with inner thread and outer thread, e.g. https://www.tme.eu/pl/details/tp-11/tuleje-dystansowe-plastikowe/fixfasten/. Please refer to photo below: the outher thread is cut flush with the display PCB board, then glued. The spacer bolt is fixed onto the UI board with adhesive tape.
Option 2 plastic spacer bolt with two inner threads, e.g. https://www.tme.eu/pl/details/hp-10/tuleje-dystansowe-plastikowe/fixfasten/. This spacer bolt is fixed with display PCB by screw and fixed to UI PCB by adhesive tape.
Display Brightness
The LCD display brightness can be adjusted by changing R105 (15 Ohm default) to a different vlue. R105 is next to the SOIC8-IC
According to LCD data sheet the maximum DC current allowed is 60 mA continous, or 75 mA for less than a minute. When changing R105 please make sure not to exceed 60 mA.
Reducing R105 to 10 Ohm typically allows to increas brightness (if needed) while staying within specifications.
Cutting SDO line
Note: It is necessary to cut the SDO line for all LCD display boards delivere befor January 5, 2018. Displays delivered later have this modification already.
Pleae cut the PCB trace as shown in photo. This is the SPI SDO “data output” line from display. This line does not go tri-state in tri-state mode. It needs to be cut so that the tuch screen controller ADS8743 / TSC2046 can not be detected by UI board MCU Display.
Display Assembly
Note: The display board is delivered as an assembled and tested unit. Explanations below refer to self-assembly, not required, and are added for completeness and reference only
This pdf contains th modified assembly notes: lcd_35_40pin_df8oe_sp9bsl.pdf
- C103 not needed anymore
- R101 = R104 = 100K
- R106 = 1K
- R102 = 15R
- all 10u now replaced by 1u
- XPT2046 = ADS7843E
DF8OE suggest to replace the two parallel tantal capacitors next to the 3.3V voltage regulator by 100nF & 1uF. He also suggest to put 100nF & 1uF in the free location shown in Andy's photo.
The two pads of R107 location need to be short cut, otherwise the LCD won't work.
Only LCD parallel mode is supported at this time.
Possitioning the LCD on the PCB
The lower left corner of the LCD should be flush with the PCB.
On shortening the male header J103 on OVI40 UI for LCD display
Cutting the male header pins pf J103 (on component side) is required to reduce height of the LCD Display module above OVI40 UI PCB. Cutting / shortening the pins on component side might not be the best idea as it damages the female connector each time it's inserted, due to the fact that cutting the J103 pins produces sharp edges that scratch the femaile LCD display header.
An alternative is to solder the pins at the right depth and then cut the pins flush to the pcb on the solder side.
