Differences
Last revisionBoth sides next revision | |||
en:operations:uhsdrops [15.02.2018 15:58] – created df9ts | en:operations:uhsdrops [15.02.2018 16:20] – additional info df8oe | ||
Line 2: | Line 2: | ||
===== UHSDR Operations ===== | ===== UHSDR Operations ===== | ||
- | ==== Reset all settings to defualt | + | ==== Reset all settings to default |
* Switch off OVI40UI | * Switch off OVI40UI | ||
* Press and hold push buttons F1 F3 F5 | * Press and hold push buttons F1 F3 F5 | ||
Line 8: | Line 9: | ||
* Press simultaneously Band+ and Band- buttons to confirm resetting of settings | * Press simultaneously Band+ and Band- buttons to confirm resetting of settings | ||
* When UHSDR has bootet up long-press System Menu (F1 button) to save values | * When UHSDR has bootet up long-press System Menu (F1 button) to save values | ||
+ | Hint: | ||
+ | If you just want to play around with default setting without loosing your own configuration: | ||
+ | * do NOT press MENU long | ||
+ | * do NOT switch off via power button because that stores active settings to EEPROM - just pull off power supply. | ||
