uhsdr:uhsdrbl
Nächste Überarbeitung
uhsdr:uhsdrbl [06.02.2018 18:06] df9ts_useruhsdr:uhsdrbl [13.02.2018 16:47] (aktuell) – [Option 3: USB-Stick Upgrade] df9ts
Zeile 45: Zeile 45:
 === Arbeitsschritte === === Arbeitsschritte ===
-ToDo+<bootnote>ToDo</bootnote>
 === Further Reading === === Further Reading ===
Zeile 53: Zeile 53:
   * [[http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-programmers/stsw-link004.html|ST-Link SW utility available at bottom of this page]]   * [[http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-programmers/stsw-link004.html|ST-Link SW utility available at bottom of this page]]
-==== Option 2: DeFuse Tool upgrade ==== +==== Option 2: DeFuse Tool Upgrade ====
-ToDo+
-=== Preconditions === +=== Vorbedingungen ===
-  * Download latest bl-40SDR.dfu bootloader from [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|here]].    +  * Neueste Datei bl-40SDR.dfu von [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|hier herunterladen]].
-  * Install ST-Micro DeFuse Tool: [[http://www.st.com/en/development-tools/stsw-stm32080.html|http://www.st.com/en/development-tools/stsw-stm32080.html]] +  * ST-Micro DeFuse Tool installieren: [[http://www.st.com/en/development-tools/stsw-stm32080.html|http://www.st.com/en/development-tools/stsw-stm32080.html]]
-  * Connect PC with OVI40 UI via USB - to - MiniUSB cableUse MiniUSB plug on OVI40 UI  +  * PC mit OVI40 UI über USB - to - MiniUSB Kabel verbindenAm OVI40 UI die MiniUSB Buchse nehmen!
-  * ST-Micro DFuse SW installed on PC and running, USB drivers installed, OVI40 UI recognized by PC +  * ST-Micro DFuse SW auf PC installiert und läuft, USB Treiber installiert, OVI40 UI wird von PC als USB Gerät erkannt
-  * OVI40 UI powered up with 5V (JP1)+  * OVI40 UI mit +5V versorgt (JP1)
-=== Procedure === +=== Arbeitsschritte ===
-  * Boot loader installation described {{:projekte:ovi40-sdr:bootloader_install.pdf|here}}+  * Boot loader Installation wird {{:projekte:ovi40-sdr:bootloader_install.pdf|hier beschrieben}}
-=== Further reading ===+=== Weiterführende Doks ===
   * {{ :uhsdr:en.cd00155676.pdf | ST-Micro DFuse Tool description}}   * {{ :uhsdr:en.cd00155676.pdf | ST-Micro DFuse Tool description}}
   * [[http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-programmers/stsw-stm32080.html|DfuSe Ressources and SW (bootom of page)]]   * [[http://www.st.com/content/st_com/en/products/development-tools/software-development-tools/stm32-software-development-tools/stm32-programmers/stsw-stm32080.html|DfuSe Ressources and SW (bootom of page)]]
-==== Option 3: USB-Stick upgrade upgrade ==== +==== Option 3: USB-Stick Upgrade ====
-ToDo+
-  * Download latest bl-40SDR.bin bootloader from [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|here]].    +  * Neueste bl-40SDR.bin Datei herunterladen [[https://www.amateurfunk-sulingen.de/uhsdr/bootloader-latest/OVI40/|von hier]].
-  * Format USB-Stick with FAT file partition. MAke sure - just in case - that USB-stick is otherwise empty +  * USB-Stick formatieren mit FAT oder FAT32
-  * Copy .bin file to stickMake sure it is copied as filenot just a link / short-cut  +  * bl-40SDR.bin auf Stick kopierenSicherstellendaß die Datei kopiert wurde und nicht nur ein Shortcut zur Datei
-  * OVI40 UI powered up with 5V (Pin 28 JP1) and 8V (Pin 29 JP1) and GND (Pin 30 JP1). The 8V powers the USB stick via voltage regulator +  * OVI40 UI mit +5V versorgen (Pin 28 JP1) und +8V (Pin 29 JP1) und GND (Pin 30 JP1). +8V versorgt den USB Stick über Spannungsregler
-  * Recent UHSDR boot loader installed and working+  * Neuerer UHSDR Bootloader auf OVI40 UI installiert und läuft ok
-  - Supply +8V on JP1 pin 29 - to pwer USB stick +  - Taste "BAND -" drücken und gedrückt halten
-  - Push and - important - hold switch "BAND -" +  - +5V an JP1 pin 28 legen dadurch startet der Bootloader
-  - Supply +5V on JP1 pin 28 - this starts the boot loader +  - USB stick in große USB Buchse des OVI40 UI stecken
-  - insert USB stick into large USB port of OVI40 UI +  - Warten, bis FW Programmierung fertig ist
-  - Wait for FW upload to finish +  - "Band -" loslassen
-  - Release switch "Band -" +  - +5V entfernendann wieder anlegen um OVI40 UI erneut zu booten.
-  - Remove +5V, then apply again to reboot OVI40 UI.+
-==== Check proper working of newly loaded boot loader ====+[{{:uhsdr:i40_32.jpg?400|Bootloader Upgrade per USB Stick (Photo DL8EBD)}}]
-Remove Jumper P6 if previously closed, then boot UI.+==== Bootloader auf korrekte Funktion prüfen ====
-Check boot loader version number displayed in system menu corresponds to the version you intended to install.+Jumper P6 öffnen, falls er zuvor geschlossen wurde, dann OVI40 UI booten.
-===== UHSDR Bootloader further reading =====+Beim starten der OVI40 UI sollte bei korrekter Installation folgender boot loader splash screen sichtbar sein:
 +[{{:uhsdr:i40_33.jpg?400|Boot loader splash screen / Startbildschirm}}]
 +Bitte auch Bootloader version im Firmware System Menü prüfen.
 +===== UHSDR Bootloader - Weiterführende Doks =====
 Forum: Forum:
   * [[https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=551;start=75]]   * [[https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=551;start=75]]
  • uhsdr/uhsdrbl.txt
  • Zuletzt geändert: 13.02.2018 16:47
  • von df9ts
