Differences
en:uhsdr_dev:win10_toolchain [25.02.2018 10:04] – [Using Git with GNU-MCU-Eclipse] df9ts_user | en:uhsdr_dev:win10_toolchain [25.02.2018 11:23] – df9ts_user | ||
Line 6: | Line 6: | ||
* Install and test | * Install and test | ||
* Gnu Arm toolchain from here, Win32 exe [[https:// | * Gnu Arm toolchain from here, Win32 exe [[https:// | ||
- | * Execute downloaded file. Tick "add to path" | + | * Execute downloaded file. Tick "add to path". |
* Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major | * Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major | ||
* See [[https:// | * See [[https:// | ||
Line 39: | Line 39: | ||
* Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev | * Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev | ||
* Get latest MCU Eclipse from here [[https:// | * Get latest MCU Eclipse from here [[https:// | ||
- | * Extract downloaded zip file to c:\ (otherwise path names may become too long) | + | * Extract downloaded zip file to c: (otherwise path names may become too long) |
* Run GNU MCU Eclipse | * Run GNU MCU Eclipse | ||
* Follow work space preferences " | * Follow work space preferences " | ||
Line 67: | Line 67: | ||
* For OVI40 with F7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32F767ZI | * For OVI40 with F7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32F767ZI | ||
* For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI | * For OVI40 with H7 MCU: Project → Properties → C/C++ Build → Settings → Devices → STM32H743ZI | ||
+ | ==== Check for updates ==== | ||
+ | * in Eclipse Help-> | ||
==== Using Git with GNU-MCU-Eclipse ==== | ==== Using Git with GNU-MCU-Eclipse ==== | ||
=== Option: Github Desktop === | === Option: Github Desktop === | ||
* Download Github desktop from [[https:// | * Download Github desktop from [[https:// | ||
- | * Start Github Desktop, enter your Githu username and password, clone repository " | + | * Start Github Desktop, enter your Githu username and password, clone repository " |
+ | |https:// | ||
- | === Option: git commandline === | ||
- | * create directory where UHSDR repository should reside, e.g. d: | ||
