Both sides previous revision Previous revision Next revision | Previous revision Next revisionBoth sides next revision |
en:uhsdr_dev:win10_toolchain [25.02.2018 10:04] – [Using Git with GNU-MCU-Eclipse] df9ts_user | en:uhsdr_dev:win10_toolchain [25.02.2018 11:21] – df9ts_user |
* Install and test | * Install and test |
* Gnu Arm toolchain from here, Win32 exe [[https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads|https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads]] | * Gnu Arm toolchain from here, Win32 exe [[https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads|https://developer.arm.com/open-source/gnu-toolchain/gnu-rm/downloads]] |
* Execute downloaded file. Tick "add to path". | * Execute downloaded file. Tick "add to path". |
* Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major | * Installs in C:\Program Files (x86)\GNU Tools ARM Embedded\7 2017-q4-major |
* See [[https://gnu-mcu-eclipse.github.io/toolchain/arm/install/|https://gnu-mcu-eclipse.github.io/toolchain/arm/install/]] | * See [[https://gnu-mcu-eclipse.github.io/toolchain/arm/install/|https://gnu-mcu-eclipse.github.io/toolchain/arm/install/]] |
* Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev | * Will install in C:\Program Files\GNU ARM Eclipse\QEMU\2.8.0-201612271623-dev |
* Get latest MCU Eclipse from here [[https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/|https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/]] | * Get latest MCU Eclipse from here [[https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/|https://github.com/gnu-mcu-eclipse/org.eclipse.epp.packages/releases/]] |
* Extract downloaded zip file to c:\ (otherwise path names may become too long) | * Extract downloaded zip file to c: (otherwise path names may become too long) |
* Run GNU MCU Eclipse | * Run GNU MCU Eclipse |
* Follow work space preferences "global tool chain path" in [[https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/|https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/]] | * Follow work space preferences "global tool chain path" in [[https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/|https://gnu-mcu-eclipse.github.io/eclipse/workspace/preferences/]] |
==== Using Git with GNU-MCU-Eclipse ==== | ==== Using Git with GNU-MCU-Eclipse ==== |
=== Option: Github Desktop === | === Option: Github Desktop === |
* Download Github desktop from [[https://desktop.github.com/|https://desktop.github.com/]] | * Download Github desktop from [[https://desktop.github.com/|https://desktop.github.com/]] |
* Start Github Desktop, enter your Githu username and password, clone repository "https://github.com/df8oe/UHSDR" * Optional: create local branch of cloned repo for tests * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository * Check Eclipse settings for * active build config * MCU device used * … | * Start Github Desktop, enter your Githu username and password, clone repository "https://github.com/df8oe/UHSDR" * Optional: create local branch of cloned repo for tests * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository * Check Eclipse settings for * active build config * MCU device used * … === Option: git commandline === * create directory where UHSDR repository should reside, e.g. d:\uhsdr''git clone [[https://github.com/df8oe/UHSDR |
| |https://github.com/df8oe/UHSDR ]]'' ===Import git UHSDR project into Eclipse installation === * In Eclipse, choose “File→Import”. * .. then choose “General→Existing Projects into Workspace”. * Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory” * The project is now recognized and can be imported * Next: check Eclipse settings // |
=== Option: git commandline === | |
* create directory where UHSDR repository should reside, e.g. d:\uhsdr<code>git clone https://github.com/df8oe/UHSDR</code> | |
