Differences
en:uhsdr_dev:uhsdrimport [06.02.2018 06:58] – dfu generation df9ts_user | en:uhsdr_dev:uhsdrbuild [14.02.2018 17:41] – [Debug, tracing, real-time diagnostics] df9ts | ||
Line 1: | Line 1: | ||
- | {{tag> | + | {{tag> |
- | ===== UHSDR development - uhsdr import into gnu arm eclipse ===== | + | ===== UHSDR development - Build using eclipse ===== |
==== Preconditions, | ==== Preconditions, | ||
- | * ... | + | * UHSDR toolchain installed, see [[en:uhsdr_dev:toolchain|here]] |
- | * https:// | + | |
==== Pull UHSDR source from Github, import into eclipse ==== | ==== Pull UHSDR source from Github, import into eclipse ==== | ||
Line 20: | Line 16: | ||
* The project is now recognized and can be imported | * The project is now recognized and can be imported | ||
- | ==== Next step: compile, load to OVI40 ==== | + | ==== Build UHSDR using eclipse ==== |
+ | * Project -> Build Configurations -> Set Active -> DebugLibOVI40 (OVI49 DSP Library (STM32F7)) | ||
+ | * Click on the " | ||
+ | * Watch Console window in Eclipse - if all ok console output ends with " ... Build finished ..." | ||
+ | * Project -> Build Configurations -> Set Active -> DebugOVI40 (OVI40 Firmware (STM32F7) ...) | ||
+ | Newly built binary fw-ovi40.bin can be found in the eclipse project explorer (left sidebar): mchf-eclipse -> DebugOVI40 -> fw-ovi40.bin | ||
+ | ==== Download new firmwar .bin to OVI40 UI ==== | ||
+ | * Please refer to [[https:// | ||
+ | * UHSDR FW build should run. | ||
+ | * Hit switch " | ||
==== Generate .dfu file from .bin file ==== | ==== Generate .dfu file from .bin file ==== | ||
+ | With .bin file the FW can be installed via USB stick of ST-Link/V2 adapter. | ||
+ | You may want to create a dfu file from the bin file so that the DfuSE FW install method can be used. | ||
+ | Section 4.2.1 of STM manual UM0412 describes step-by-step the generation of a .dfu file. | ||
The ST-Micro UM0412 manual on DfuSe can be found {{ : | The ST-Micro UM0412 manual on DfuSe can be found {{ : | ||
- | Section 4.2.1 of UM0412 describes | + | ==== Eclipse user guide ==== |
+ | * User guide can be found [[https:// | ||
+ | * Profiling is described [[http:// | ||
+ | This covers basic usage as well as advanced tools such as profiling and others. | ||
+ | ==== Debug, tracing, real-time diagnostics ==== | ||
+ | * [[http:// | ||
+ | * [[https:// | ||
+ | * Concurrent use of ST-Link debugger and SWO Viewer not possible, see [[http:// | ||
+ | * J-Link Debug Probe [: | ||
+ | * https:// | ||
+ | * https:// | ||
+ | * SWV and SWO and Eclipse explaind [[https:// | ||
