Differences
Link to this comparison view
Next revision
Previous revision
Next revisionBoth sides next revision
en:uhsdr:uhsdrtroubleshooting [06.02.2018 16:42] – created df9ts_useren:uhsdr:uhsdrtroubleshooting [12.02.2018 20:01] df9ts
Line 43: Line 43:
 === 3. Debug cable === === 3. Debug cable ===
 The debug cable shouldn't be longer than 10 cm. 3 to 4 connections are needed. The debug cable shouldn't be longer than 10 cm. 3 to 4 connections are needed.
-|< 40% 50% 50% >| +|< 60% 50% 25% 25% >|
-|  ST-link UI   JP8  | +|  ST-link adapter  |  OVI40 UI JP8  |
- JTAG-9 SWCLK    JP8 Pin  | +|Pin-13 TRACESWO  |JP8 Pin 1  |Debug Output  |
-|  JTAG-SWDIO   JP8 Pin 3  | +|Pin-15 NRST      |JP8 Pin 2  |Reset         |
- JTAG-20 Gnd   JP8 Pin  |  +|Pin-07 SWDIO     |JP8 Pin 3  |Debug I/O
- not essential: Signal: Reset   JP8 Pin  |+|Pin-09 SWCLK     |JP8 Pin  |Debug Clock
 +|Pin-01 MCU VDD   |JP8 Pin 5  |VDD from MCU
 +|Pin-20 Gnd       |JP8 Pin  |Ground        |
 {{ :uhsdr:en.dm00026748.pdf |Beschreibung ST-Link V2 und ST-Link ISO Adapter, Pin out}} {{ :uhsdr:en.dm00026748.pdf |Beschreibung ST-Link V2 und ST-Link ISO Adapter, Pin out}}
  • en/uhsdr/uhsdrtroubleshooting.txt
  • Last modified: 26.02.2018 18:58
  • by df9ts_user
