Differences
en:projekte:ovi40-sdr:bom [08.12.2017 11:29] – yd0rwo | en:projekte:ovi40-sdr:bom [07.02.2018 06:07] – df9ts_user | ||
Line 1: | Line 1: | ||
+ | ===== Bill of Material (BoM) ===== | ||
Here you can find the recent Bill of Materials for OVI40-SDR. | Here you can find the recent Bill of Materials for OVI40-SDR. | ||
- | ====== UI-PCB: | + | ==== UI-PCB: ==== |
**Please pay attention! This BOM is a preliminary and might change during betatest phase.** | **Please pay attention! This BOM is a preliminary and might change during betatest phase.** | ||
Line 17: | Line 20: | ||
|IC6|KA78RM33R|3, | |IC6|KA78RM33R|3, | ||
|IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/ | |IC7|AT24CM02|I2C EEPROM|SO08|1| | |24LC1026_ISN| |579-24LC1026I/ | ||
- | |IC8|NCP5501DT50G|5, | + | |IC8|NCP5501DT50G|5, |
|Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0, | |Q1|32,768 kHz|QCM-315_SMD|CM315|1| | | | |695-CM315D-32.7KEZFT| |300-8813-1-ND|0, | ||
|T3|BC857|PNP Transistor|SOT23|1|179-8067|0, | |T3|BC857|PNP Transistor|SOT23|1|179-8067|0, | ||
Line 26: | Line 29: | ||
|D9|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | | |D9|BAS85|Schottky barrier diode|SOD80C|.| | | | | | | | | | ||
- | |D1|green|LED|LED_3MM|1|276-4976|0, | + | |D1|green|LED|LED_3MM|1|276-4976|0, |
- | |D2|red|LED|LED_3MM|1|276-4977|0, | + | |D2|red|LED|LED_3MM|1|276-4977|0, |
- | |D3|blue|LED|LED_3MM|1|276-4975|0, | + | |D3|blue|LED|LED_3MM|1|276-4975|0, |
|BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2, | |BAT1-HOLDER| |Battery Holder CR2032| |1|188-5903|2, | ||
|BAT1|CR2032P_L|Lithium Battery 3, | |BAT1|CR2032P_L|Lithium Battery 3, | ||
Line 35: | Line 38: | ||
|LCD1|HY32D|3, | |LCD1|HY32D|3, | ||
- | |L1|47uH|L_SMD1005|L1005|3|221-5655|0, | + | |L1|47uH|L_SMD1005|L1005|3|221-5655|0, |
|L2|47uH|L_SMD1005|L1005|.| | | | | | | | | | |L2|47uH|L_SMD1005|L1005|.| | | | | | | | | | ||
|L3|47uH|L_SMD1005|L1005|.| | | | | | | | | | |L3|47uH|L_SMD1005|L1005|.| | | | | | | | | | ||
- | |R1|47k|SMD Resistor TK50|0805|6| | |SMD-0805 47k|0,02| | | | | | + | |R1|47k|SMD Resistor TK50|0805|6| | |SMD-0805 47k|0,02|667-ERJ-U06F4702V| | | | |
- | |R1A|100R|SMD Resistor TK50|0603|13| | |SMD-0603 100|0,03| | | | | | + | |R1A|100R|SMD Resistor TK50|0603|13| | |SMD-0603 100|0,03|667-ERJ-3RBD1000V| | | | |
- | |R1B|0R|SMD Resistor TK50|0603|3| | |SMD-0603 0|0,03| | | | | | + | |R1B|0R|SMD Resistor TK50|0603|3| | |SMD-0603 0|0,03|667-ERJ-3GEY0R00V| | | | |
- | |R2|1k|SMD Resistor TK50|0603|7| | |SMD-0603 1,0k|0,03| | | | | | + | |R2|1k|SMD Resistor TK50|0603|7| | |SMD-0603 1,0k|0,03|667-ERJ-S03F1001V| | | | |
|R3|100R|SMD Resistor TK50|0603|.| | | | | | | | | | |R3|100R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
|R4|1k|SMD Resistor TK50|0603|.| | | | | | | | | | |R4|1k|SMD Resistor TK50|0603|.| | | | | | | | | | ||
- | |R4B1|2R2|SMD Resistor TK50|1206|4| | |SMD ¼W 2,2|0,03| | | | | | + | |R4B1|2R2|SMD Resistor TK50|1206|4| | |SMD ¼W 2,2|0,03|71-CRCW12062R20FNEB| | | | |
|R4D|2R2|SMD Resistor TK50|1206|.| | | | | | | | | | |R4D|2R2|SMD Resistor TK50|1206|.| | | | | | | | | | ||
|R5|0R|SMD Resistor TK50|0603|.| | | | | | | | | | |R5|0R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
Line 51: | Line 54: | ||
|R7|1k|SMD Resistor TK50|0603|.| | | | | | | | | | |R7|1k|SMD Resistor TK50|0603|.| | | | | | | | | | ||
|R8|100R|SMD Resistor TK50|0603|.| | | | | | | | | | |R8|100R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
- | |R9|4k7|SMD Resistor TK50|0805|4| | |SMD-0805 4,7k|0,02| | | | | | + | |R9|4k7|SMD Resistor TK50|0805|4| | |SMD-0805 4,7k|0,02|667-ERJ-S06F4701V| | | | |
- | |R10|4k7|SMD Resistor TK50|0603|1| | |SMD-0603 4,7k|0,02| | | | | | + | |R10|4k7|SMD Resistor TK50|0603|1| | |SMD-0603 4,7k|0,02|667-ERJ-3EKF4701V| | | | |
|R11|4k7|SMD Resistor TK50|0805|.| | | | | | | | | | |R11|4k7|SMD Resistor TK50|0805|.| | | | | | | | | | ||
|R12|4k7|SMD Resistor TK50|0805|.| | | | | | | | | | |R12|4k7|SMD Resistor TK50|0805|.| | | | | | | | | | ||
- | |R13|47R|SMD Resistor TK50|0603|7| | |SMD-0603 47|0,03| | | | | | + | |R13|47R|SMD Resistor TK50|0603|7| | |SMD-0603 47|0,03|667-ERJ-3EKF47R0V| | | | |
|R14|47R|SMD Resistor TK50|0603|.| | | | | | | | | | |R14|47R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
|R15|1k|SMD Resistor TK50|0603|.| | | | | | | | | | |R15|1k|SMD Resistor TK50|0603|.| | | | | | | | | | ||
Line 65: | Line 68: | ||
|R21|47R|SMD Resistor TK50|0603|.| | | | | | | | | | |R21|47R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
|R22|47R|SMD Resistor TK50|0603|.| | | | | | | | | | |R22|47R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
- | |R23|0R|SMD Resistor TK50|0805|8| | |SMD-0805 0|0,02| | | | | | + | |R23|0R|SMD Resistor TK50|0805|8| | |SMD-0805 0|0,02|667-ERJ-U060R00V| | | | |
- | |R24|680R|SMD Resistor TK50|0805|4| | |SMD-0805 680|0,02| | | | | | + | |R24|680R|SMD Resistor TK50|0805|4| | |SMD-0805 680|0,02|ERJ-6ENF6800V| | | | |
|R25|4k7|SMD Resistor TK50|0805|.| | | | | | | | | | |R25|4k7|SMD Resistor TK50|0805|.| | | | | | | | | | ||
|R26|100R|SMD Resistor TK50|0603|.| | | | | | | | | | |R26|100R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
Line 77: | Line 80: | ||
|R33|100R|SMD Resistor TK50|0603|.| | | | | | | | | | |R33|100R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
|R34|100R|SMD Resistor TK50|0603|.| | | | | | | | | | |R34|100R|SMD Resistor TK50|0603|.| | | | | | | | | | ||
- | |R35A|4R7|SMD Resistor TK50|1206|1| | |SMD ¼W 4,7|0,03| | | | | | + | |R35A|4R7|SMD Resistor TK50|1206|1| | |SMD ¼W 4,7|0,03|71-CRCW12064R70FNEB| | | | |
|R36|680R|SMD Resistor TK50|0805|.| | | | | | | | | | |R36|680R|SMD Resistor TK50|0805|.| | | | | | | | | | ||
|R37|680R|SMD Resistor TK50|0805|.| | | | | | | | | | |R37|680R|SMD Resistor TK50|0805|.| | | | | | | | | | ||
Line 220: | Line 223: | ||
|C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | | |C125|8,2pF – 10pF|SMD Chip Capacitor|0603|.| | | | | | | | | | ||
- | |S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0, | + | |S1|G3|SMD Pushbutton KSC941J| |18|243-5157|0, |
|S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S2|G2|SMD Pushbutton KSC941J| |.| | | | | | | | | | ||
|S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | | |S3|M2|SMD Pushbutton KSC941J| |.| | | | | | | | | |
