Topic: Does UHSDR support the ESP8266 wifi? (Read 2269 times)
k6pc
« on: 27. May 2018, 04:39:11 »
Hello, I'm building my first mcHF and noticed the ESP8266 option. I am wondering if the firmware supports it?
Thanks! Matt - K6PC
k6pc
Re:Does UHSDR support the ESP8266 wifi?
« Reply #2 on: 27. May 2018, 07:09:08 »
Andreas, thanks for the quick response!
Wifi might be nice for cat control with a tablet PC out in the field. But not at the expense of the touchscreen!
Thanks again! Matt - K6PC
« Reply #4 on: 27. May 2018, 12:05:11 »
.... If you would be able to connect audio with WIFI - complete other story. But that does not work.
with a different layout (using for instance a ESP8266 ESP12 module), story is different since then you have even I2S available, no need to go through serial as it is with the ESP8266 ESP01 module design on the mchF. Still doesn't solve the GPIO pin problem of the mcHF, though.
As Andreas said, the current design doesn't give sufficient benefit for what it takes from you. And this in turn seems to let developers avoid support for this option as it creates a lot of work for not much to gain. But anyone should feel free to prove otherwise.
