Topic: Bad PA job outside of amateur bands (Read 3224 times)
« on: 13. May 2018, 21:03:03 »
Hi
| « Last Edit: 29. June 2022, 21:06:56 by SP3OSJ » |
pa3met
Re:Bad PA job outside of amateur bands
« Reply #2 on: 14. May 2018, 12:02:14 »
on the other hand, if you want to drive a transverter I could think of the use of such frequencies. Obviously extreme high levels shoudl not be useable
Somethink like 26.....30 MHz to cover 4 MHz in the 70 or 23cm band. Or maybe even 144.....148 MHz transverters,
For 11m... well I fully agree on that one. (including the other bands, like 45m, etc the pirates seem to use)
« Reply #3 on: 14. May 2018, 15:43:50 »
for the transverter use case you are right, and this might be a use case which we could support at some point. I indicated that to Artur, SP3OSJ in a different there in this forum, where I also mentioned the low power rule outside amateur bands. In order to have somewhat consistent power output and TX IQ across a larger freqency range, we would need to add more calibration points and some other stuff. So it is most likely not a simple `we turn that "stupid" limitation off` thing.
