Re:[gelöst] Magnify Modes beim 480x320 LCD
« Reply #15 on: 30. January 2018, 10:43:28 »
Hast Du die Anteilige Anzeigehöhe auch mal neu angepasst? |
| Sorry, da muss ich jetzt mal doof nachfragen WO das zu machen ist ? Vermutlich unter "Display Settings" nehme ich an ?! Hätte jetzt gedacht das da ein adäquater Wert der Vorgänger Versionen übernommen wird der ein Nachjustieren erstmal nicht erforderlich macht aber ich pass das natürlich gerne an wenns denn wirklich daran liegt ?! Was wäre denn da ein gängiger Wert ?
« Last Edit: 30. January 2018, 10:44:19 by peter_77 » |
positron alter Hase
« Reply #16 on: 30. January 2018, 10:47:49 »
Hi Peter, just simply press and hold the frequency ruler, next you will be able to set its new position. After this do not forget to save to eeprom (long press MENU). There is no menu item regarding this setting (yet).
« Last Edit: 30. January 2018, 10:48:05 by SP9BSL » |
« Reply #17 on: 30. January 2018, 10:53:41 »
Thats very convenient and "Winblows like". Sorry for the dumb question. And what should i say...it works as designed ;-)
« Reply #18 on: 30. January 2018, 11:45:15 »
Everything is fine with the 3.5" display now and i made some further tests with the same firmware under the 3.2" display. Here it seems that there is still an error in the spectrum display together with magnifying. Dial screen and positionig works fine as well as waterfall. But if you go to spectrum display only its fine as long as you stay into magnify 1. Immediately if you choose a magnify number grater than 1 the spectrum display vanishes slowly under the frequency bar but never comes up. That happens in all stages from 2 to 32. When you go back to 1 everything is fine. Spectrum comes back overloaded but regulates itself into fitting the screen.
I tried to reproduce that on th 3.5" and on a classical mcHF with 2.8" but here behaviour is fine. Looks like only the 3.2" display is affected by this. Screenshot before:
« Reply #19 on: 30. January 2018, 11:45:54 »
After:
« Reply #21 on: 30. January 2018, 11:52:22 »
I have 2.7.74 running on the 3.2" box as well. The only thing i haven't done so far on that UI is changing the bootloader to the latest and greatest but i guess this is without any influence on the above behaviour. I will now do it, just to be sure...
« Last Edit: 30. January 2018, 12:06:07 by peter_77 » |
« Reply #23 on: 30. January 2018, 12:00:23 »
What is strange... I just switched the box off with magnify left on 2 and then back on and...things work ! Now magnify 2 and above work without any error. Sounds funny but it looks like the old German "AEG" (Auschalten, Einschalten, Geht !) solved the issue. It is not reproducable anymore. Tried that 5 times. (Bootloader not updated so far)
« Last Edit: 30. January 2018, 12:01:33 by peter_77 » |
« Reply #25 on: 30. January 2018, 12:04:12 »
Yepp, same here. Weired ! But if we can fix it that way who cares ?
positron alter Hase
« Reply #26 on: 30. January 2018, 12:53:56 »
hmmm... have to play with it... Code is getting more complicated and there could be something we missed...
« Last Edit: 30. January 2018, 12:54:32 by SP9BSL » |
DD4WH
positron alter Hase
« Reply #27 on: 30. January 2018, 13:21:33 »
just a guess:
sd.magnify is uint8_t and old_magnify in UiSpectrum_UpdateSpectrumPixelParameters is uint16_t ?
and force_update will never become false in that function
But I may be totally on the wrong track . . .
73 Frank
