Topic: Mate OVI40-SDR UI board to mcHF PA (Read 1566 times)
Mike-K0JTA
« on: 24. April 2018, 14:11:17 »
Can I directly plug your OVI40-SDR UI board into a mcHF version .4 PA board? (And have it function correctly, as desired or expected?)
I have an mcHF radio did has no PTT, but it Transmits ten watts in TUNE mode. (Just SSB and AM modes are bad, as there is NO PTT action at all.) The receiver etc. all works wonderfully; -I just have no PTT actions or indications. (Again, the TUNE mode does emit a proper ten watt carrier!)
It is my desire to be able to plug in your UI PC board into my mcHF version .4 PA board, and have a functional transceiver. (I am assuming that the interconnect pins are common wiring or connections?)
Are the interconnect pin connections COMMON between your UI board and my version .4 mcHF PA board?
Will your UI board fill this need for me?
WONDERFUL looking project!! (Congratulations!)
Thank you, Mike, K0JTA
Mike-K0JTA
Re:Mate OVI40-SDR UI board to mcHF PA
« Reply #2 on: 24. April 2018, 16:29:13 »
Very GOOD!
I THANK YOU!
73 from Mike, K0JTA
