29. April 2024, 18:31:07
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  OVI40 SDR Projekt (English AND German discussions around OVI40 SDR project) (Moderators: DF8OE, DL1PQ)  |  Topic: S7 S8 <- zurück vorwärts ->
   Author  Topic: S7 S8  (Read 1949 times)
sm0nor
S7 S8
« on: 10. March 2018, 15:45:17 »
Hi,I'm wondering about S7 and S8. There are two ways to mount them. I can see on the pictures that they should be mounted on the upper 4 pads. But what is the purpose of this?
/Ulf
Re:S7 S8
« Reply #1 on: 10. March 2018, 16:32:57 »
OVI40 will be available in future with bigger LCDs. This is the "non-portable" version. Because of LCD should be place on the same lower level as smaller LCD these buttons have to move down (or they will conflict with larger LCDs)... For larger LCDs the VFO encoder will move away from its PCB place.
sm0nor
Re:S7 S8
« Reply #2 on: 10. March 2018, 18:34:03 »
Ok. Thanks!
dstirrup
Re:S7 S8
« Reply #3 on: 11. March 2018, 22:51:07 »
Hi Andreas,
I am not building a portable version.  What display pixel format are we going up to?  1024 x 600? in 7" or 10"
Also what controller support is currently available for Parallel and touch interfaces?
Re:S7 S8
« Reply #4 on: 12. March 2018, 06:49:19 »
Actually ILI9486 controllers using resolution 480x320 are supported. The "standard LCD" is a 3.5" LCD - and this will be "the edge" for portable use. We are not currently working on higher resolutions and/or other controllers because there are many other much higher priority works to be done.
dstirrup
Re:S7 S8
« Reply #5 on: 12. March 2018, 11:17:12 »
Thank you.
So I now have a target
