03. July 2025, 02:16:30
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Correct way of keying an amplifier? <- zurück vorwärts ->
   Author  Topic: Correct way of keying an amplifier?  (Read 3602 times)
sm0nor
« on: 15. May 2022, 19:07:02 »
Hi all,
I don't understand how to key the amplifier with the mchf? My amplifier is home built and requires only to ground the TX-relays in the amp to ground. This doesn't work with the mchf accessory output (outer ring). From what I understand from the mchf diagram there is an optocoupler pulling the outer ring to ground on TX.
I also think I might have destroyed the optocoupler. On TX the resistance collector-emitter on the coupler measures about 600 ohms. (I have no trouble replacing it if I have destroyed it).
73's
SM0NOR - Ulf
Re:Correct way of keying an amplifier?
« Reply #1 on: 16. May 2022, 03:33:59 »
The optocoupler is a poor solution. It only can provide a few milliamps with a quite high resistance (as you already observed). It can/should be replaced by a solid state relay. These are available (if they are available...) in same package so you can do a drop-in-replacement.
sm0nor
« Reply #2 on: 16. May 2022, 18:03:45 »
Thank you for the good idea of replacing the optocoupler with a SSR. I'll look for that for my next Mouser-order.
Meanwhile I quickly breadboarded a simple switch around a PNP-transistor and a relay which I put in the amplifier. The mchf ACC output keys this the normal way. So, after all, the optocoupler is still in business.
73's
Ulf - SM0NOR
DJ0MDJ
« Reply #3 on: 21. May 2022, 07:37:16 »
I am interested in the solid state relay as a drop-in replacement.
Which one would be suitable?
Welcher Typ für das Solid State Relay als direkten Ersatz für den Optokoppler würde passen?
73, Chris
Lötest Du noch, oder funkst Du schon?
« Reply #4 on: 21. May 2022, 08:16:17 »
Alle mit der gleichen Gehäuseform, der gleichen Pin-Belegung, einer Schaltspannung von <=5V und der Fähigkeit >48V 1A (für fette Röhrenendstufen - obwohl ich das für sinnfrei halte) zu schalten. Da gibt es sehr viele Typen - leider dank Halbleiterkrise nur ein Bruchteil lieferbar. Schau einfach mal bei Digikey und wühle Datenblätter durch.
Steven
« Reply #5 on: 21. May 2022, 08:26:41 »
zB einen Baustein von OMROM aus der G3VM Serie
Quote from: DF8OE on 21. May 2022, 08:16:17
 K302-E1.pdf
« Last Edit: 21. May 2022, 08:40:15 by Steven »
DJ0MDJ
« Reply #6 on: 21. May 2022, 15:23:23 »
Vielen Dank für die Hinweise!
Ich denke, das Omron G3VM-61D1 müsste passen.
Es kann bis 500mA schalten und das ist genug für meine Yaesu FL-110 Endstufe.
Bei Reichelt ist das zur Zeit noch verfügbar.
Ob das vom IMD3 her noch vertretbar ist, muß ich dann noch messen.
Ich hatte bei meinem mcHF 0.6.3 mal richtig schlechte Werte gemessen, allerdings später herausgefunden, dass der TX RF Preamp HMC482ST89E defekt war.
73, Chris
« Last Edit: 21. May 2022, 15:24:12 by DJ0MDJ » Logged
« Reply #7 on: 22. May 2022, 07:18:24 »
Ich habe schon sehr viele verschiedene mcHFs bezüglich qualitativem TX-Signal geprüft und bin (vor ca. 4 Jahren) zu dem Schluß gekommen dass der mcHF das ist was er sein will: "a cheap homebrew SDR". Keine Verwendung von Endstufen oder Transvertern sinnvoll. Es ist nicht nur das IMD3 - es sind auch zahlreiche andere Nebenprodukte die alle störend werden wenn man sie verstärkt oder in "ruhigere Bändern" raufmischt.
« Last Edit: 22. May 2022, 07:19:05 by DF8OE » Logged
