29. April 2024, 23:08:33
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Two-balanced RX mixer <- zurück vorwärts ->
   Author  Topic: Two-balanced RX mixer  (Read 1072 times)
satoryboy
« on: 12. April 2021, 07:13:54 »
I am posting for discussion a modified circuit of a two-balanced RX mixer. The gain is 11 for both inputs of the differential amplifiers, the input impedances are 2.2 kOhm. Not much, but in the classic mcHF circuit there is generally 100 ohms.
IZ6MAF
Re:Two-balanced RX mixer
« Reply #1 on: 12. April 2021, 18:12:05 »
I suggest you try these changes that I applied to the Eagle last year. '73 IZ6MAF Paolo
 QRP_Transceiver_RF_Board_Sampling_detector.pdf
satoryboy
« Reply #2 on: 13. April 2021, 01:25:43 »
Thanks, I read this post.
