Pages: [1]
Topic: Low drive, 10 meters (Read 3065 times)
WD8BXS
« on: 22. September 2020, 17:53:14 »
I have one (mcHF) on the bench, and it has low drive on the upper bands.
It has similar signals at the output of T5 on all bands, but on the upper bands there is low output on the drivers Q3 and Q4. I have tried new ones, but same result.
I have another radio here with the same type drivers and it does not show the same results, it has good driver out put on the upper bands.
Any ideas??
Tnx, Chuck
| « Last Edit: 22. September 2020, 22:14:24 by WD8BXS » |
Thanks, De WD8BXS vy 73
WD8BXS
Re:Low drive, 10 meters
« Reply #2 on: 23. September 2020, 12:39:45 »
Hi Andreas,
Yes, that is what I am doing. That is how I have arrived at these results.
I have good signals to driver input.
Low signal on driver output on 17 meters and up.
WD8BXS
« Reply #4 on: 23. September 2020, 16:31:17 »
Yes, I desoldered the 2 100nf and no change. I will examine the other part values. I have tried 2 new transistors, could all be bad??
Chuck
WD8BXS
« Reply #6 on: 23. September 2020, 23:29:49 »
Bought from Mousers
« Reply #7 on: 24. September 2020, 05:00:20 »
Mousers, Digikey, Farnell do not sell fakes. You have definitely one of the other mentioned issues. For bug hunting you need in optimum a spectrum analyzer (for looking what you are amplifying), an oscilloscope (signal amplitude checking), a DVM (checking DC states at drivers, checking BIAS of drivers), an inductor tester (or VNA) for checking health of collector inductors.
| « Last Edit: 24. September 2020, 05:00:39 by DF8OE » |
positron alter Hase
« Reply #8 on: 24. September 2020, 07:08:01 »
Hi, I would suggest to check the collector coils, 47uH often has self resonance around 10MHz. Try to insert lower value coil for experiment, let's say 4.7uH and check if the higher bands signal level rise.
Pages: [1]
