26. May 2024, 00:28:58
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: USB Keyboard <- zurück vorwärts ->
   Author  Topic: USB Keyboard  (Read 1232 times)
WD8BXS
USB Keyboard
« on: 27. April 2020, 23:39:08 »
I have a Rii mini X1 bluetooth keyboard, and it does not work with my mcHF..
I thought that it used to work, or am i imagining that??
Should it work? has something changed?
Thanks, 73
Chuck
Thanks,
De WD8BXS vy 73
Re:USB Keyboard
« Reply #1 on: 28. April 2020, 05:00:01 »
Chuck, you have 5 volts on the USB socket and a keyboard with cable works on this mcHF?
maybe the Bluetooth dongle needs a driver?
stay healthy!
Re:USB Keyboard
« Reply #2 on: 28. April 2020, 07:06:40 »
If it is BLUETOOTH: no chance. If it is WIRELESS and has a receiver which identifies as keynoard or HID: I think it will work.
vy 73 - stay healthy
WD8BXS
Re:USB Keyboard
« Reply #3 on: 28. April 2020, 12:46:32 »
Sorry, it is not bluetooth, my mistake.
It is just a wireless keyboard.
I thought that it was recommended my you sometime ago. I may be wrong, I am old and the memory fails me at times.
Here is a picture of it maybe it will be recognized.
Chuck
Thanks,
De WD8BXS vy 73
Re:USB Keyboard
« Reply #4 on: 28. April 2020, 13:12:45 »
Yes, this one works out-of-the-box and perfectly.
WD8BXS
Re:USB Keyboard
« Reply #5 on: 28. April 2020, 13:29:24 »
I thought that is did at one time, but it is not working on the mchf.. I have tried it on 2 different mchf radios but no go.
It works on my desktop computer, so I know the keyboard is working ok
I have 5v at UBS connector, but it will not connect.
Any ideas?
Tnx, 73 Chuck
Thanks,
De WD8BXS vy 73
Re:USB Keyboard
« Reply #6 on: 28. April 2020, 13:48:49 »
I have two of this and they work on mcHF and OVI40. Only explanation is they have changed the behaviour of the USB dongle so that is no longer compatible with UHSDR. But I do not have a keyboard of this kind that does not work...
WD8BXS
Re:USB Keyboard
« Reply #7 on: 28. April 2020, 15:59:37 »
This an older unit, I bought it when I first was that it was compatible.
I have to assume that there is an issue with the mcHF radios I have here as to why it will not work.
It would seem that if the dongle has power it should communicate with the keyboard.
I am not getting the yellow connect LED.
Chuck
Thanks,
De WD8BXS vy 73
Re:USB Keyboard
« Reply #8 on: 29. April 2020, 03:54:06 »
The yellow connect LED will turn on if the dongle is provided with 5V supply. No ned for any communication on the two USB DATA pins. If the yellow connect LED will not turn on maybe the 5V are not 5V but 4.5V or your keyboard is malfunctioning...
WD8BXS
Re:USB Keyboard
« Reply #9 on: 29. April 2020, 12:28:10 »
Praise the Lord, it is working now, Andreas, all you had to do was think about it!
You are magic.
Thanks,
Chuck
Thanks,
De WD8BXS vy 73
