WD8BXS
USB Keyboard
« on: 27. April 2020, 23:39:08 »
I have a Rii mini X1 bluetooth keyboard, and it does not work with my mcHF.. I thought that it used to work, or am i imagining that??
Should it work? has something changed?
Thanks, 73 Chuck
Thanks, De WD8BXS vy 73
Re:USB Keyboard
« Reply #1 on: 28. April 2020, 05:00:01 »
Chuck, you have 5 volts on the USB socket and a keyboard with cable works on this mcHF? maybe the Bluetooth dongle needs a driver?
stay healthy!
WD8BXS
Re:USB Keyboard
« Reply #3 on: 28. April 2020, 12:46:32 »
Sorry, it is not bluetooth, my mistake. It is just a wireless keyboard. I thought that it was recommended my you sometime ago. I may be wrong, I am old and the memory fails me at times.
Here is a picture of it maybe it will be recognized.
Chuck
WD8BXS
Re:USB Keyboard
« Reply #5 on: 28. April 2020, 13:29:24 »
I thought that is did at one time, but it is not working on the mchf.. I have tried it on 2 different mchf radios but no go.
It works on my desktop computer, so I know the keyboard is working ok
I have 5v at UBS connector, but it will not connect. Any ideas?
Tnx, 73 Chuck
WD8BXS
Re:USB Keyboard
« Reply #7 on: 28. April 2020, 15:59:37 »
This an older unit, I bought it when I first was that it was compatible. I have to assume that there is an issue with the mcHF radios I have here as to why it will not work.
It would seem that if the dongle has power it should communicate with the keyboard.
I am not getting the yellow connect LED.
Chuck
WD8BXS
Re:USB Keyboard
« Reply #9 on: 29. April 2020, 12:28:10 »
Praise the Lord, it is working now, Andreas, all you had to do was think about it! You are magic.
Thanks, Chuck
