Topic: menu Enhancement (Read 1164 times)
WD8BXS
menu Enhancement
« on: 05. February 2020, 18:23:33 »
Hi All, I thought since all has been going well with the new IQ adjustments , maybe you could move them all to the config menu along with the original settings. Then we can just go right down the list.
Also I think the default value would be much better set at zero. I have found that the completed values all are close to zero. So having the default at zero, you won't have to crank the knob as much hihi
Just a few thoughts,
Thank you so much for all you do!!
Thanks, De WD8BXS vy 73
WD8BXS
Re:menu Enhancement
« Reply #2 on: 06. February 2020, 15:17:11 »
Hi Andreas,
That is interesting, I have not had the same results on 10 meters.
But I have only done 30 or so.
Thanks for the information, we can leave as "off", it will be OK to disagree, hihi
Blessed day my friend,, de Chuck WD8BXS
