08. November 2026, 07:29:04
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Another puzzler V6.3 <- zurück vorwärts ->
   Author  Topic: Another puzzler V6.3  (Read 2547 times)
WD8BXS
« on: 25. December 2019, 13:24:25 »
Setting up a radio, 5 watts out all ok.
Full power out is strange,
increasing the drive past 5 watts and the power comes back down.
Scratching my head hihi
Merry Christmas to all!
Chuck
Thanks,
De WD8BXS vy 73
Re:Another puzzler V6.3
« Reply #1 on: 26. December 2019, 09:03:49 »
Hi Chuck,
Merry Christmas to you and your family, too!
Regarding your TX problem: follow the signal using a scope. Start at the TX mixer output. Signal will start to cripple at some stage in TX chain. This can be many reasons: bad soldering, defective parts (semiconductor, inductor), wrong parts (wrong wound transformers, wrong inductor in BPF).
You must take a look at the signal...
WD8BXS
« Reply #2 on: 28. December 2019, 14:11:42 »
Thanks Andreas,
Turned out to be faulty relay.
Relay would change state after a few seconds of powering the radio on.
A strange one!
Chuck
Thanks,
De WD8BXS vy 73
« Reply #3 on: 28. December 2019, 14:44:57 »
I agree. But it is possible to locate even very strange things by logical approaches (best with digital answer possibilities yes/no). Now you can step forward until you reach the black hole where strange things happen
Chuck - Good Luck for 2020!
