Topic: 6.3 puzzler (Read 1238 times)
WD8BXS
6.3 puzzler
« on: 09. December 2019, 11:58:17 »
new build 6.3
Won't see USB drive for firmware update.
data lines check OK, 5v and ground ok.
Firmware loads fine with Dfu, radio works OK
Just can't use UBS port. Thoughts??
Chuck
Thanks, De WD8BXS vy 73
WD8BXS
Re:6.3 puzzler
« Reply #2 on: 09. December 2019, 12:22:19 »
Can't be #3
no need for driver to see USB Stick.
So must be 1 or 2.
Will try another MCU next.
Chuck
« Last Edit: 09. December 2019, 12:22:53 by WD8BXS » |
WD8BXS
Re:6.3 puzzler
« Reply #4 on: 17. December 2019, 14:01:41 »
Sorry Andreas, I did not read your #3 correctly. I thought it said driver not drive hi hi.
What is the meaning of red and green flashing when trying to load firmware from USB drive ??
Chuck
« Last Edit: 17. December 2019, 15:01:31 by WD8BXS » |
WD8BXS
Re:6.3 puzzler
« Reply #6 on: 28. December 2019, 14:10:22 »
Yes, you are correct.
Thanks de Chuck WD8BXS
