Pages: [1]
Topic: Power output down, red (TX) light flashing (Read 1270 times)
S58J
« on: 24. September 2019, 06:45:53 »
Hi
Together with Marko, S54AM we are struggling to identify the erratic behaviour of his mcHF. They appeared suddenly after years of normal use, after latest FW upgrade.
The simptoms: Power ON procedure - OK Receiver - OK Transmit - OK (with nominal power) for a couple of seconds than power goes down and RED (TX) LED is flashing maybe another 2 seconds after end of TX.
When restarting (Power OFF / ON) the simptoms start to repeat as listed above.
Any idea?
Kind regards
Janez, S58J
Re:Power output down, red (TX) light flashing
« Reply #1 on: 24. September 2019, 06:57:10 »
Janez, maybe a starting point: Look in the menu "Debug/ Exper. Settings" under "VSWR Protect.threshold". You can set this to "Off" if there is a SWR limit set.
« Last Edit: 24. September 2019, 06:58:08 by DL8EBD » |
S58J
« Reply #2 on: 24. September 2019, 08:17:28 »
Hi Thomas
Thanks for your proposal. Before doing that I have to tell you that the same thing happens with dummy load (SWR 1:1.0) connected.
Kind regards
Janez, S58J
S58J
« Reply #4 on: 24. September 2019, 11:35:22 »
Thank you Thomas, thank you Andreas.
Your proposal solved the problem! We can close this thread.
Marko, S54AM also send you both a big thank you.
Kind regards
Janez, S58J
Pages: [1]
