12. July 2025, 07:10:19
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: rotary encoders boucing <- zurück vorwärts ->
Pages: 1 [2] Go Down Print
   Author  Topic: rotary encoders boucing  (Read 5910 times)
Re:rotary encoders bouncing
« Reply #15 on: 29. May 2018, 14:15:39 »
Slawek is right here. In the configuration menue this is reproducable either on the mcHF or I40-UI.
Not the way that its not functioning at all but the right left behaviour is somehow "shaky".
EDIT
corrected typo in thread title
« Last Edit: 04. June 2018, 16:52:06 by DF8OE » Logged
Re:rotary encoders boucing
« Reply #16 on: 29. May 2018, 16:23:53 »
I think like Danilo. It is a combination of hardware problem and "simple firmware interpretation".
If you want to code a debouncing filter this would cause more delay in firmware processing, more code and probably new configuration for different encoders.
So best is to add a RC lowpass between encoder contacts and GPIOs. You need three parts: one resistor as pullup (already present built-in STM), a capacitor to GND (already present) and a serial resistor between contact and GPIO/capacitor (missing). So you can cut the track and insert it. I never have had tried but I thin 1K...3.3K will do the job. But pay attention! Screwing up resistor will cause lower maximum pulses ( ==> you cannot turn very fast). I would think hardware lowpass is sufficient for volume, AGC and RIT but not for VFO.
OE3HKC
« Reply #17 on: 29. May 2018, 19:55:48 »
Hallo Allerseits,
und auf "deutsch" würde ich sagen...
prellende Kontakte können so manches verursachen...
ich habe in meinem MiniTRX die Encoder-Kontakte über pullup 4k7, dann Serien-Widerstand 100 Ohm und Ko von 1n gegen 0V "entprellt"...
diese Probleme mit "falscher" Drehrichtung habe ich bisher noch nicht festgestellt.
Ich verwende auch die preisgünstigen Encoder von ALPS...
Schaltbild dazu unter
https://www.amateurfunk-sulingen.de/forum/attachments/MINIMCU.PDF
MiniMCU.pdf
vy 73, Helmut
« Last Edit: 29. May 2018, 20:09:43 by OE3HKC » Logged
« Reply #18 on: 31. May 2018, 08:27:33 »
As a conclusion following Helmuts advice would would mean to simply cut the encoder lines and add a 100Ohm resistor.
Thats a quick fix.
Looks like Helmut has done here too much as he has not taken into account that the STM CPU has an internal pullup resistor on chip and the 1nF capacitor is there anyway either on mcHF and I40-UI.
« Last Edit: 31. May 2018, 08:28:20 by peter_77 » Logged
S53DZ
« Reply #19 on: 31. May 2018, 11:07:01 »
Hi there,
I did some LTspice simple simulations of contact bouncing.
I have used an optocoupler for that.
It seems that a lower value pull-down resistor makes a difference.
Perhaps the slope of end pulse could be important here for FW level-decision.
Just guessing.
Beside that, my experience is: don't use the cheapest encoders.
73 Bojan
 Bounce.pdf
« Reply #20 on: 31. May 2018, 16:31:23 »
Hi Bojan,
as Danilo said, the problem lies somewhere between the hardware and firmware. I always use ALPS encoders wchich are known as good ones, and i met this issue in mcHF/OVI40. From other side, i replaced few unknown encoders in stuff like Hameg/Rigol oscilloscopes/spectrum analyzers, and the new ones from ALPS works much better and longer than those mounted in factory.
Increase of capacitance and/or series resistance may cause problems with slope as mentioned. This issue doesn't occur with magnetic encoder chip (AS5040, AS5601) I use, so I think that this leads to conclusion that we have slope problem.
« Reply #21 on: 03. June 2018, 18:03:49 »
Beside the slope, there is also zero crossing counter issue for sure. Anyway: workin' on it...
« Reply #22 on: 04. June 2018, 06:41:32 »
Please test the new 2.9.34 version. It contains fixup for encoder boundary crossing and hardware filter usage (internal STM settings) for encoder sampling. Hope this will work better. For my mcHF, after this fixup, the issue is no longer reproduceable.
« Reply #23 on: 04. June 2018, 14:03:11 »
Tested and works perfectly fine now. The hangers are not reproducable anymore. Either on mcHF or I40.
Good job Slawek !
« Reply #24 on: 04. June 2018, 16:09:02 »
Hi Peter,
thank you for the report. This part of code is very old and still needs some cleanup.
I'm curious of reports from others who changed the encoder capacitors to bigger than in schematics.
« Reply #25 on: 04. June 2018, 16:51:36 »
You should ask in Yahoo group because of changing capacitors is mainly mentioned to 0.7 boards whichs layout is not rf resistent
« Reply #26 on: 04. June 2018, 18:51:56 »
Hi Andreas,
I will do so.
OE3HKC
« Reply #27 on: 04. June 2018, 19:08:00 »
TNX Slawek for your great work,
I also tested the new version with my MiniTRX..
sometimes there were little boucings, only some few, perhaps because of the small pullup of 4k7...
but now there is no more issue from the encoders and I think it is not necessary to change it for a magnetic type...
73, Helmut
Pages: 1 [2] Go Up Print
