04. May 2024, 22:52:26
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: Power Off problem <- zurück vorwärts ->
   Author  Topic: Power Off problem  (Read 1711 times)
ve3ll
Power Off problem
« on: 05. May 2018, 21:28:55 »
I have problem with Power button on my RS-918.  When I connect power connector to the radio Transceiver powered on without Power button. And when when I press power button to turn off the transceiver it does not power off. I have measured voltage on pin 2 of U3 (LM2941CT)/ when transceiver On voltage is 0.2 v, when I press Power button to off the transceiver voltage raise to 2.97 v. But transceiver does not power off. Need to remove power connector to turn off the transceiver. Can anybody to help me to solve this problem? Thanks.
« Last Edit: 05. May 2018, 21:30:52 by ve3ll » Logged
Re:Power Off problem
« Reply #1 on: 06. May 2018, 16:53:56 »
Sorry - no.
If you do use newest version of firmware AND bootloader and problem persists: it is a hardware problem related to clone and we do not know any solution.
« Reply #2 on: 07. May 2018, 10:37:31 »
YouTube describes how this is quickly done:
https://www.youtube.com/watch?v=MXfTxMnCoGE
ve3ll
« Reply #3 on: 08. May 2018, 01:44:08 »
Yes, I have install latest software. Nothing change.
« Last Edit: 08. May 2018, 01:44:30 by ve3ll » Logged
« Reply #4 on: 08. May 2018, 06:46:40 »
Bootloader AND firmware are recent and from our source? This issue is related to firmware AND bootloader (or it is a hardware issue).
