allgemeine Kategorie => mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) => Message started by: ve3ll on 05. May 2018, 21:28:55
Title: Power Off problem
Post by: ve3ll on 05. May 2018, 21:28:55
I have problem with Power button on my RS-918. When I connect power connector to the radio Transceiver powered on without Power button. And when when I press power button to turn off the transceiver it does not power off. I have measured voltage on pin 2 of U3 (LM2941CT)/ when transceiver On voltage is 0.2 v, when I press Power button to off the transceiver voltage raise to 2.97 v. But transceiver does not power off. Need to remove power connector to turn off the transceiver. Can anybody to help me to solve this problem? Thanks.
Title: Re:Power Off problem
Post by: DF8OE on 06. May 2018, 16:53:56
Sorry - no.
If you do use newest version of firmware AND bootloader and problem persists: it is a hardware problem related to clone and we do not know any solution.
Post by: peter_77 on 07. May 2018, 10:37:31
YouTube describes how this is quickly done:
https://www.youtube.com/watch?v=MXfTxMnCoGE (https://www.youtube.com/watch?v=MXfTxMnCoGE)
Post by: ve3ll on 08. May 2018, 01:44:08
Yes, I have install latest software. Nothing change.
Post by: DF8OE on 08. May 2018, 06:46:40
Bootloader AND firmware are recent and from our source? This issue is related to firmware AND bootloader (or it is a hardware issue).
