sm0nor
IC7
« on: 11. February 2018, 13:58:04 »
About IC 7...
Is this IC supplied in bag 3 (photo) the same as the AT24CM02 specified in the BOM?
It ought to be as it is the only one matching the pin konfiguration. But, better safe than sorry...
How about the pin configuration?
/Ulf SM0NOR
Re:IC7
« Reply #1 on: 11. February 2018, 14:49:00 »
yes it is Ulf!
System Info says 24CM02/256K
and please leave R101 open
Re:IC7
« Reply #2 on: 11. February 2018, 15:15:53 »
And the little, barely visible dot is the pin 1-marker.
73, Harri
sm0nor
Re:IC7
« Reply #4 on: 11. February 2018, 19:59:29 »
I soldered it, but I see now on the diagram that it is optional. So, depending on the type the 0 ohm resistor should be either in place or not in place. Correct? And for the IC type I have, it should not be in place? Correct? /ulf
Re:IC7
« Reply #5 on: 11. February 2018, 20:12:11 »
correct Ulf, leave it open
« Last Edit: 12. February 2018, 05:31:39 by DL8EBD » |
