LY1AGU
Problems UI with F7/H7
« on: 08. February 2020, 14:21:18 »
It's time to ask for help. Assembled 2 pieces OVI_UI_V1.8.
Processor STM32H743ZIT6V; Ser.7B658VQ,. DFU / P6 - PC can't see. I programmed with ST-Link V2. Bootloader uhsdr / bootloader-latest / OVI40 / H7 2019-01-23 0x08000000 Firmware OVI40 / H7 2019-12-24 0x08010000 Programming and verification passes normally. Verify file alignment with programmed data matches. Power 3.3V is available. Reset (25 foot) C94 with 57KOhm works - rises to 1.9V. The IC5 (ASTX-H11) 3-pin provides a 16MHz signal with a 1.7V amplitude. But that's it. White screen, CPU I / O not enabled. I feel like the program does not start. Maybe Option bytes or MCU Core something not right?
LY1AGU
Re:Baubericht: UI mit 480MHz STM32H743ZIT6U
« Reply #1 on: 08. February 2020, 14:23:32 »
and MCU Core
DO9AH
« Reply #2 on: 08. February 2020, 16:06:56 »
In einem früherem Post gab es diese Erkenntnis:
0x08060000 ist für die Firmware beim H7(!!) korrekt...
vy 73, Andreas
LY1AGU
« Reply #3 on: 08. February 2020, 16:48:18 »
Thank you Andreas,
I tried to write firmware in H7 from address 0x08060000. Didn't help. White screen, no reaction.
What amazes me is that even after performing the Erase Chip procedure, I / O remains undefined, i.e. 0. The same remains the same when Bootloader and Firmware are programmed. For example, the PG2 should be at High Level (to read a push of a button). And with me practically 0.
I think the processors are defective, but ST-Link gets along normally.
« Reply #5 on: 08. February 2020, 17:18:50 »
please check your RTC crystal! No 32768hz = gets stuck at boot-up
LY1AGU
« Reply #6 on: 08. February 2020, 17:34:26 »
Thanks Andreas (DO9AH) Thank you Andre (DF8OE), You have shown me the right way. Now the UI starts.;D There were two problems: 1) I missed the information that the firmware in H7 from address 0x08060000. Andre (DO9AH) showed my mistake. But it didn't help; 2) Andreas (DF8OE) advised not to touch the processor and look closely at Option Bytes. And sure. Boot_From (H) was 0x00800000. And it should be 0x08000000. After the change everything started. The truth remains unclear what should be written in BOOT_ADD1 (H). But still thank you very much.
Thomas, I'm obviously not an expert, but with the quartz not working in RTC, I think the processor won't communicate with the ST-Link Utility either.
« Reply #7 on: 08. February 2020, 18:17:38 »
Without or wrong RTC crystal you can flash normally via ST-Link. The firmware still won't boot.
LY1AGU
« Reply #8 on: 08. February 2020, 19:10:41 »
Thank you, I understood. I didn't know. What about: what should be written in BOOT_ADD1 (H).
positron alter Hase
« Reply #9 on: 08. February 2020, 21:26:09 »
For H7 bootloader the start address (BOOT_ADD0) is :
rom (rx) : ORIGIN = 0x08000000, LENGTH = 32k |
the application code start is:
rom (rx) : ORIGIN = 0x08060000, LENGTH = 2048k - 384k |
We do not use the BOOT_ADD1 feature so you may write there what you want. I would recommend same as BOOT_ADD0 (H).
The STLink will communicate with STM (any) without RTC crystal, the firmware will not start if waiting for RTC peripherial to initialize, I'm not sure how it works in our F7/H7 firmware when there is no such crystal.
« Last Edit: 08. February 2020, 21:33:15 by SP9BSL » |
LY1AGU
Re:Problems UI with F7/H7
« Reply #10 on: 09. February 2020, 13:01:13 »
Now everything is in order. I think others will be clearer. Men, your support is above any praise. Thank you.
Werner
« Reply #11 on: 09. February 2020, 17:56:26 »
Hallo Andreas,Thomas und Slawek,
dank Eurer Hilfe konnte heute auch mein UI-Board vom " Sparrow " die ersten Schritte machen !!!
Die bl und fw habe ich nach meinem Wissen auf die Adr. 0x08000000 und 0x08010000 mit dem " ST-Link V2 " und den bin Dateien ohne Fehlermeldung übertragen. Alles ohne Erfolg,das 4" Display von Artur zeigte nur einen hellen Hintergrund ! Ihr habt mich mit Eurem Beitrag erst darauf gebracht,ich habe bl u.fw nochmal kpl. gelöscht, den bl auf die alte adr und die fw auf die "0x08060000 übertragen.
Mein Sparrow UI Board Aufbau und Test durch das Forum wurden nun zum Erfolg !
Dank Eurer Hilfe !!! Denn ich hatte schon einen Tag um dem RTC -Quarz gesucht. ich kann nur sagen, "ich liebe dieses Forum " !!!
vy73 Werner
« Reply #12 on: 09. February 2020, 19:10:43 »
für alle die mitlesen und noch vor der Inbetriebnahme stehen:
Die sinnvolle Reihenfolge bei der ersten Installation eines UI Boards ist: - Bootloader via ST-Link installieren oder per DFU Mode. - jetzt testen, ob das Display funktioniert (dazu Power+Band Plus oder Band Minus drücken beim Starten) - dann Firmware via Bootloader aufspielen, der stellt sicher, das die richtige Datei an die richtige Stelle geflasht wird.
Der Bootloader braucht auch den 32.768 khz Quartz nicht, auch nicht bei den F7/H7 Boards. Das direkte Aufspielen per ST-Link von Bin-Files sollte Ausnahmefällen vorbehalten sein.
« Reply #13 on: 09. February 2020, 19:29:54 »
Danilo is right here. There is even no need for an ST-Link it can too easily be done with the standard DFuse tool.
Btw. in the early beginings of UI I40 board i kind of bricked my STM MCU as well when flashing the first beta style bootloaders. All the predefined register settings were somehow messed up and that issue of course needs an ST Link cable to fix. But only that case. You can read the whole story and the fixing process here: https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=577;start=315
Somewhere Andreas, DF8OE provided the correct register settings to restore normal operation but i cannot find the link to this thread anymore...
« Last Edit: 09. February 2020, 19:37:33 by peter_77 » |
