17. May 2024, 02:24:34
Diskussions- und Newsboard des DARC-Ortsverbandes I40  |  allgemeine Kategorie  |  mcHF Projekt Deutsch / English (here you can discuss everything related to mcHF) (Moderators: DF8OE, DL1PQ)  |  Topic: IQ calibration problem <- zurück vorwärts ->
   Author  Topic: IQ calibration problem  (Read 1497 times)
F5AGL
Je suis un lama!
« on: 27. February 2021, 06:50:37 »
Hello,
I am bored with the IQ calibration phase of my mcHF (M0NKA kit version 0.6.3).
I am having trouble reducing the carrier to 3.600 MHz LSB (mcHF to 3.624 MHz USB). The problem is the same on the other tapes.
I installed the latest firmware and bootloader:
- Firmware: D2.11.95
- Bootloader: 5.0.4
The problem remains the same.
Do you have any indication of the possible origin of this problem?
73 qro
Gilles, F5AGL
Re:IQ calibration problem
« Reply #1 on: 27. February 2021, 09:14:12 »
Hi Gilles,
if the suppression is very poor there is a hardware issue in the IQ chain. So it is important to know if the suppression is very bad or not. IQ calibration only works if hardware chain is not defective.
« Last Edit: 28. February 2021, 16:33:52 by DF8OE » Logged
F5AGL
Je suis un lama!
« Reply #2 on: 27. February 2021, 09:33:02 »
yes, i think i can say the suppression is very bad.
« Reply #3 on: 27. February 2021, 10:26:37 »
If it is very bad check the following signals:
  • i and q local oscillator signal at mixer
  • solderings at the input transformer
  • (audio) signal from output of the mixer over the op-amp to the input of the audio codec. I think one of these signals is lost. If it is so you will have bad suppression and correction does not work at all.
    Good luck
F5AGL
Je suis un lama!
« Reply #4 on: 27. February 2021, 16:41:40 »
Thanks for your help.
I follow signal from IQ oscillator to mixer, solderings at input transformer (T4), audio signal from UI board to RF bard, all links seems ok with ohmmeter.
Could it be a configuration problem ?
Gilles F5AGL
« Reply #5 on: 27. February 2021, 17:16:53 »
No. It is a hardware problem. You must use a scope for bug hunting.
F5AGL
Je suis un lama!
« Reply #6 on: 27. February 2021, 19:33:09 »
At the first power up, i had a problem with C105 (10 uF PA part). Fuse blow up. I replaced C105 and after that mcHF was OK. RX is all ok. TX seems to be quite ok (5-10W). But i have this pb of IQ calibration. If I put 127 for TX Phase on 80m for example, side carrier reduce a little bit. But i can't cancel it as it could be. I test all links around TX Mixer, LO, etc... I have no scope at this moment... I tried with +6kHz translation in place of -12, it's the same...
« Reply #7 on: 28. February 2021, 08:07:10 »
You need a scope for tracing the signals.
F5AGL
Je suis un lama!
« Reply #8 on: 28. February 2021, 10:07:54 »
yes, that's right, i'm going to test this with a scope.
« Reply #9 on: 28. February 2021, 15:02:58 »
IQ calibration only works if hardware chain is defective.
Is that sentence really true or is there a "not" missing before defective ?!
« Reply #10 on: 28. February 2021, 16:35:24 »
Hi Peter,
thank you for reading this thread. Of course there is a "not" missing. I have read my own post many times but my brain always automatically placed it where it is missing
F5AGL
Je suis un lama!
« Reply #11 on: 28. February 2021, 16:49:19 »
I had understoodd !
