ovi40wiki:wikitodo
Nächste Überarbeitung
ovi40wiki:wikitodo [07.02.2018 15:21] df9tsovi40wiki:wikitodo [19.02.2018 13:37] (aktuell) – alte Version wiederhergestellt (15.02.2018 07:11) df9ts
Zeile 1: Zeile 1:
-{{tag>german}}{{tag>stub}} +{{tag>german}}{{tag>publish}}
-===== Wiki Howto =====+
 +===== Wiki ToDo =====
   * Check why Discussion cannot be switched off per page   * Check why Discussion cannot be switched off per page
   * Try to disable translation outdated warning   * Try to disable translation outdated warning
-  * Neue Seiten einfach anlegen und einpflegen
-  * Tips und Tricks zum Wiki, z.B. Suche
   * UHSDR Beschreibung à la https://github.com/df8oe/UHSDR/wiki/Technical-Specifications-of-mcHF   * UHSDR Beschreibung à la https://github.com/df8oe/UHSDR/wiki/Technical-Specifications-of-mcHF
-  * Tagging: für korrekte pagelist braucht jede Seite eine Überschrift ähnlich Seitennamen
-  * Include info from Nov / Dez 2017 I-Net articles on OVI40 (also for English text)
   * UI Board Blockdiagram based on OVI40 UI schematics, style example [[http://www.m0nka.co.uk/wp-content/uploads/2013/12/block_diag.jpg|here]]    * UI Board Blockdiagram based on OVI40 UI schematics, style example [[http://www.m0nka.co.uk/wp-content/uploads/2013/12/block_diag.jpg|here]]
   * Inbetriebnahme   * Inbetriebnahme
Zeile 14: Zeile 11:
     * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=517     * https://www.amateurfunk-sulingen.de/forum/index.php?board=15;action=display;threadid=517
     * http://www.ov-selbstbau.de/doku.php?id=de:projects:pro_tut_6:pro_tut_6     * http://www.ov-selbstbau.de/doku.php?id=de:projects:pro_tut_6:pro_tut_6
-  * Do and test OpenOCD https://gnu-mcu-eclipse.github.io/debug/openocd/ on toolchain page +  * Align German and English versions of [[:ovi40test:uiboardtest]]
-  * One multilangage wiki todo page? (This collides with the language setting to change UI with language with content) +  * Check tags used actually, compare with page overview for gaps
-  * Translate ovi40what:description to English, check content +  * In uhsdr:uhsdrtroubleshooting complete debug cable with trace output TRACESWO
-  * Translate to English[[:ovi40test:uiboardtest]]+  * Implement language detection https://www.dokuwiki.org/tips:browserlanguagedetection - use browser language detection to automatically to switch to en fr de (the languages currently used in wiki) all other should go to English?
 +  * Add STM32 device signatures for F7 H7 and F4 used https://www.amateurfunk-sulingen.de/forum/index.php?board=18;action=display;threadid=1025;start=0#lastPost
 ==== Stub Seiten - diese Seiten müssen noch erstellt werden ==== ==== Stub Seiten - diese Seiten müssen noch erstellt werden ====
Zeile 31: Zeile 29:
 {{topic>publish nofirsthl&tags&date&nouser&table}} {{topic>publish nofirsthl&tags&date&nouser&table}}
 +====Include Seiten ====
 +{{topic>include nofirsthl&tags&date&nouser&table}}
 +==== Autogenerate Seiten ====
 +{{topic>autogenerate nofirsthl&tags&date&nouser&table}}
  • ovi40wiki/wikitodo.txt
  • Zuletzt geändert: 19.02.2018 13:37
  • von df9ts
