ovi40_rfboardbuild [15.01.2018 13:33] – df9ts | ovi40build:rfboardbuild [07.02.2018 14:55] (aktuell) – df9ts | ||
- | < | + | {{tag> |
+ | ===== Nachbau RF Board ===== | ||
- | ==== Tranverterausgang ==== | ||
- | === UHSDR Transverter Settings === | ||
- | UHSDR unterstützt bereits die Transverter Offseteinstellung.\\ | ||
- | * 10m-Band | ||
- | in Config-Menü | ||
- | eine Zeile tiefer in XVTR Offs die Frequenzdifferenz einstellen (in d. Regel die Quarzfrequenz)\\ | ||
- | Ist zwar etwas mühsam, aber danach geht's (bei mir wiederholt mit DB0ETB getestet) | ||
- | === RF Board Transverter Ausgänge === | ||
- | I will add TE connectors to PCBs. The MMCX are much too big. You are free to choose the kind of adaptor you want.\\ | ||
- | I recommend not to use the " | ||
- | I will not follow the path "save each Cent I can save". In most cases "you got what you pay for". That means: "from nothing comes nothing" | ||
- | mit " | ||
