Both sides previous revision Previous revision | |
en:uhsdr_dev:win10_toolchain [13.03.2018 09:31] – df9ts_user | en:uhsdr_dev:win10_toolchain [13.03.2018 09:34] (current) – [Using Git with GNU-MCU-Eclipse] corrected scrambled formatting df9ts_user |
=== Option: Github Desktop === | === Option: Github Desktop === |
* Download Github desktop from [[https://desktop.github.com/|https://desktop.github.com/]] | * Download Github desktop from [[https://desktop.github.com/|https://desktop.github.com/]] |
* Start Github Desktop, enter your Githu username and password, clone repository "https://github.com/df8oe/UHSDR" * Optional: create local branch of cloned repo for tests * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository * Check Eclipse settings for * active build config * MCU device used * … === Option: git commandline === * create directory where UHSDR repository should reside, e.g. d:\uhsdr''git clone https://github.com/df8oe/UHSDR '' ===Import git UHSDR project into Eclipse installation === * In Eclipse, choose “File→Import”. * .. then choose “General→Existing Projects into Workspace”. * Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory” * The project is now recognized and can be imported * Next: check Eclipse settings // | * Start Github Desktop, enter your Githu username and password, clone repository "https://github.com/df8oe/UHSDR" |
| * Optional: create local branch of cloned repo for tests |
| * In Eclipse, create new workspace pointing to local clone of cloned Github UHSDR repository |
| * Check Eclipse settings for |
| * active build config |
| * MCU device used * … |
| === Option: git commandline === |
| * create directory where UHSDR repository should reside, e.g. d:\uhsdr''git clone https://github.com/df8oe/UHSDR '' |
| === Import git UHSDR project into Eclipse installation === |
| * In Eclipse, choose “File→Import”. |
| * .. then choose “General→Existing Projects into Workspace”. |
| * Then choose the folder “mchf-eclipse in the path where you just downloaded the zip file as “root-directory” |
| * The project is now recognized and can be imported * Next: check Eclipse settings |
