en:uhsdr_dev:toolchain
Differences
Link to this comparison view
Next revision
Previous revision
en:uhsdr_dev:toolchain [06.02.2018 21:40] df9ts_useren:uhsdr_dev:toolchain [06.02.2018 23:03] (current) df9ts_user
Line 1: Line 1:
-{{tag>english}}{{tag>private}}+{{tag>english}}{{tag>review}}
 <bootnote> Attention: Work in progress - page under construction</bootnote> <bootnote> Attention: Work in progress - page under construction</bootnote>
Line 86: Line 86:
 </code> </code>
 +Install OpenOCD Debugging plugin, see [[https://gnu-mcu-eclipse.github.io/openocd/install/|here]]
 +Update OpenOCD path, see [[https://gnu-mcu-eclipse.github.io/openocd/install/|here]]
 +{{ :en:uhsdr_dev:openocd.pdf |OpeOCD manual from sourceforge}} \\
 +[[https://community.particle.io/t/tutorial-using-eclipse-st-link-v2-openocd-to-debug/10042|eclipse & st-link/v2 tutorial]]
 +In Virtualbox make sure the STM-link/V2 adapter is connected through to virtual machine (check machine settings->USB)
 +In Eclipse hit green "Debug" button.
-GDB 7.12 distributed with the initial GCC 6.2 (gcc-arm-none-eabi-6_2-2016q4-20161216) has several issues (crashes on macOS and is incompatible with Neon.2).
-The recommendation is to use the update version gcc-arm-none-eabi-6-2017-q1-update, or later.
-=== Install OpenOCD ===
-  * See [[https://gnu-mcu-eclipse.github.io/openocd/install/]]
-  * Download from [[https://github.com/gnu-mcu-eclipse/openocd/releases]]
-  * Latest version is gnu-mcu-eclipse-openocd-0.10.0-5-20171110-1117-debian64.tgz
-<bootnote>ToDo https://gnu-mcu-eclipse.github.io/debug/openocd/</bootnote>
-<code>
-$ sudo mkdir -p /opt/gnuarmeclipse
-$ cd /opt/gnuarmeclipse
-$ tar xvf /home/gerd/Downloads/gnu-mcu-eclipse-openocd-0.10.0-5-20171110-1117-debian64.tgz
-</code>
-  * Test installation:
-<code>
-$ /opt/gnuarmeclipse/gnu-mcu-eclipse/openocd/0.10.0-5-20171110-1117/bin/openocd --version
-</code>
-  * Output should be like this:
-<code>
-GNU MCU Eclipse 64-bits Open On-Chip Debugger 0.10.0+dev-00254-g2ec04e4e (2017-11-10-11:27)
-Licensed under GNU GPL v2
-For bug reports, read
-http://openocd.org/doc/doxygen/bugs.html
-</code>
 === GNU MCU Eclipse and CDT === === GNU MCU Eclipse and CDT ===
   * Install Eclipse and CDT   * Install Eclipse and CDT
  • en/uhsdr_dev/toolchain.txt
  • Last modified: 06.02.2018 23:03
  • by df9ts_user
